avatar_StanP
Hemi Conversion Kit
Started by StanP, October 13, 2022, 04:47:27 PM
StanP
Looking for recommendations for a Hemi Conversion kit that contains the necessary parts to install in an 1973 E-body. Engine will be a 6.4l crate with a TorqueFlite transmission. Open to suggestions for the transmission also. Thanks in advance.
Roseville Moparts & Mancini would be the first places to check .
I have not seen a kit , usually you have to piece things together , Mounts & headers are available through TTI , Oil pans from Mancini 'or Milodon , EFI fuel tanks from Tanks Inc or Holley .
I have done a number of conversions & always had to piece it together .
Any small block trans will fit / LA belhousing , numbers of choices for Manual or Auto
Bouchillon Performance will put together everything needed, not cheap though.
I'm almost done with my swap, sourced the parts myself to save money.
Quote from: StanP on October 13, 2022, 04:47:27 PM
Is your plan to upgrade the front suspension and steering or retain the stock K-Frame ?
Silver Sport sells a nice A41 programable four speed automatic that will bolt right in  :alan2cents:
Filthy Filbert
Roseville Moparts has the closest thing to a kit; Jon emailed me an excel spreadsheet that had all the parts, their part numbers, and current pricing that's needed to swap a 6.4 into an E-body.  Including the crate engine itself, all in is about $15k and you still need to figure out a transmission.
I plan to cut that cost some by doing my own shopping.   For example, I doubt I need a $300 starter when I'm betting a $20 scrap yard Dakota starter will suffice just fine; and I should be able to buy a fuel pump and install it myself instead of spending $550 on a new tank/pump assembly.
Fern
Quote from: Filthy Filbert on October 17, 2022, 10:06:23 AM
Any chance you could upload the spreadsheet so we could see where all the money goes?
