avatar_kawahonda
Need intake coolant fitting
Started by kawahonda, October 03, 2019, 08:11:46 AM
I'm having a hard time finding a straight heater hose coolant fitting for my LD340. It does not use 1/2" NPT, but rather what seems 5/8" NPT.
Please don't tag anyone. I've already "tried" one venue.
Have you tried the HELP line of parts at your local parts store?
I haven't gone into part stores yet but I've been searching the web quite a bit!
DeathProofCuda
Quote from: Bullitt- on October 03, 2019, 08:25:38 AM
:waving:   doesn't give thread size...
https://www.manciniracing.com/hehonib.html
The big block fitting sets shown in the Mancini link look like they include a 5/8" threaded fitting.  I think I have a spare one in the garage somewhere that I can check.
The OEM fitting heater hose fitting I bought was one size too small for the LD4B intake so I just picked up a brass reducing bushing at the hardware store and got on with life.
Yea. It will all get sprayed orange anyways. Sounds like I may need a reducer.
I'm pretty sure there has to be a 5/8" NPT 1/2" Hose barb slotted fitting out there. I think just jollying around to part stores is going to create a lot of time burn.
No such thing (that I know of?)  as a 5/8 NPT thread.  likely 3/8 OR 1/2 NPT
5/8" is referring to the heater hose size
The LD340 does not have a 1/2 NPT header hose connection. A 1/2 NPT falls through the hole.....
Whatever the "long" one in this kit is (I believe 1/2" NPT) falls in the hole:
https://www.manciniracing.com/19ahehonikit.html
But I do agree that there appears to be "no such thing" based on how much I've looked!
DeathProofCuda
What is the diameter at the face of the threads for the fitting that will fall through the hole?
What is the internal diameter of the hole?
A 1/2" NPT fitting is right about 3/4" at the face of the threads.  Overall diameter is listed as 0.840"
Quote from: kawahonda on October 03, 2019, 01:09:40 PM
Tap drill size
for 3/8 NPT is 9/16 or .562
for 1/2" NPT is 45/64 or .703"
for 3/4 NPT is  29/32 or .906
Are you sure 1/2 NPT falls in?  :o
I can't find the fitting (It will pop up I'm sure), but the intake fitting bore measures .588"
I have a freeze plug fitting that threads perfectly in it, and it measures. .666"
Quote from: kawahonda on October 03, 2019, 04:00:24 PM
So if I'm understanding this right , its 3/8 NPT . It's a tapered pipe tap so it gets bigger at the opening of the hole , as you tap the tap drill sized hole the tap cuts on a tapper making the opening bigger than the tap drill size.
DeathProofCuda
 :iagree:
Here is a photo of a big block set.
The smaller one shown at the top is 1/4" NPT.  It is shown next to a 1/4" NPT air fitting.  Outside thread diameter is 0.54"
The larger one is 3/8" NPT.  It is shown next to a 3/8" NPT tap.  Outside thread diameter measures 0.66" with my caliper.
The large tap at the bottom is 1/2" NPT.  Outside thread diameter is 0.84"
#14
This is awesome.
So basically, 3/8" does not mean .375. 1/2" does not mean .50. I still don't understand that, but whatever. It must have something to do with the tapering, but I'll have to wrap my mind around it tomorrow.
Somehow, it seems that I need a 3/8" NPT according to this!
I bet if I found my fitting, it would be 1/4" NPT, which is .54". That's what it "falls into" the ".588" bore.
A 3/8" NPT slot fitting for a 1/2" hose should be easier to find, I would assume?
Probably this is what I need: https://www.summitracing.com/parts/fss-84712/overview/
Deathproof, does that hose end accept a 1/2" hose?
