rear backing plates
Started by realn96, July 24, 2017, 04:13:42 PM
realn96
what color are you guys restoring your backing plates? Paint or plated? :popcorn:
Depends on the rear end. 8 3/4 or Dana 60 ? :notsure:
realn96
Quote from: anlauto on July 24, 2017, 04:16:16 PM
sorry about that    8 3/4 !
They're usually a dull black Phosphate plating.....I try to duplicate it with various spray paints for longevity  :alan2cents:
70vcodecuda
Painted black with the rear end as an assembly :alan2cents:
realn96
Quote from: anlauto on July 24, 2017, 04:30:40 PM
That's what I was thinking of doing too for the same reason!
I tried the eastwood  zinc phosphate spray. Seams too dark to me. I know it should be a more dull look!
70vcodecuda
would the axles be installed at this time and painted as well?
750-h2
Every original Dana 60 I have ever seen had natural steel backing plates.  No black paint.
I think it changed a bit from time to time.  I've seen them both ways and can not figure out a time frame / pattern.  I think judges will let either finish pass as original.  Or do what you like to make it last.
realn96
Thanks ,as always for your help guys!
