Small hole in radiator, now what?
Started by TelisSE440, December 02, 2018, 04:57:29 AM
Quote from: A.Gramz on December 25, 2018, 09:03:41 AM
I would recommend long life coolant.  - sometimes referred to as red.  Especially with aluminum rad. Conventional requires too much ph level mantance to prevent corrosion.
Agreed. A few posts back is a pic of brand i am using with great results.
IRON MAN
Quote from: TelisSE440 on December 25, 2018, 06:30:15 AM
Due to import and shipping fees, i ordered a reasonably priced 3 row Champion aluminum radiator (if any of you have negative feedback, please advice) and it will be rubber mounted. I also got a zinc anode, so as to combat galvanic corrosion. Guys thanks for all the replies.
[/quote
]I belong to a number of forums where members are happy with the Champion radiator...I am one of them. I installed a Champion radiator in the car on the right and in the 36 roadster in the foreground, both over four years ago. No issues and cost effective. Should note both radiators have Summit's zinc anodes that go where the drain petcock was. Also, both are rubber  mounted  but  the roadster uses mounting bolts with coil springs like Henry Ford used on his Model T's , these allow the radiator to flex with the frame.  The firewall to top of radiator support rods keep the radiator perpindicular.
