avatar_blown motor
Trying to solve engine not cooling down
Started by blown motor, January 20, 2023, 12:46:24 PM
@Filthy Filbert  Sorry. Brass/copper, as in original, not aluminum. Brain fart.
Quote from: blown motor on January 30, 2023, 04:22:24 PM
I checked today and there is not a spring. For what they cost I think I'll get one and put it in.
If the hose is in fact collapsing, replace the hose. It's old. Don't add a spring. They restrict flow, not by a lot, but they reduce it.
Ya maybe I should. I doubt it's an old hose but it didn't seem to have a lot of structural integrity either.
Ramman
As far as radiators go, which is a better for cooling?
1. 2 rows of 1" tubes
2. 3 rows of 3/4" tubes
3. 4 rows of 1/2" tubes
4. It doesn't matter
Thanks group!
Quote from: dodj on January 31, 2023, 04:30:05 AM
I checked a new hose at Napa this morning and it's just as soft as the hose on the car. A spring might be the only way to go. It might restrict flow a wee bit but not near as much as a collapsed hose.
wait....why are we focused on the lower rad hose????  Did I miss something here.
Murray, you said the rad cap is lose on the Charger rad, that seems to be a problem to me.
When you said you cannot build pressure in the Charger's rad, you mean you put the pressure tester on the rad and it would not build any pressure.  Same deal when testing the cap.
If that is the case that is the problem I would focus on.  The rad should be able to hold pressure, if not you will have a problem.
If the cap is not tight, I would start with a new cap that fits properly.
@Cudajason  I picked up new rad cap this morning and this cap tested hood as it should. But...I can install fully tightened with very little pressure on one finger. I think the neck on the rad is the problem. I'll try to post a video if I can get it to load up but I had trouble doing that yesterday.
Filthy Filbert
sounds like the radiator is out of shape if the pressure tester won't seal tight enough to allow you to build pressure.
Quote from: blown motor on January 31, 2023, 10:48:53 AM
is there any indication who made the rad?
If so, then may be able to advise on the proper rad cap.
Not having used an aluminum rad before, maybe the caps seal differently, but it sounds like its still loose.
That and if you cannot build pressure with the rad tester, that indicates a bigger problem.
Cannot find any name on the red as it sits. Could remove fan shroud and look, otherwise I would have to dig deeper to try and find a name.
So this is a new cap. I can't see how the cooling system can build pressure with a cap this loose. Agree or disagreee?
Quote from: blown motor on January 31, 2023, 12:35:54 PM
Haha! I fixed it.
um no that does not look right.
I think that will be most of your problem.
