with a/c to no a/c
Started by 73TopBanana, June 26, 2019, 08:58:27 AM
73TopBanana
Morning all,
Removed all the AC components from engine and bay. Do the (2) pipes in the firewall need to be capped or plugged?
Does the engine now need a new fan pulley with (2) grooves, car has power steering.
I removed the ac in my 74 and did not cap the pipes, no problem.
73TopBanana
Generally the whole pulley system changes without AC .
So you could create an Idler where the A/C compressor was or change the pullys so you have water pump,  alt , crank on one belt & crank , PS on a second belt
The alternator mounting is totally different...grab yourself an alternator bracket kit and a top fan pulley and you're all set, maybe a two groove lower pulley as well. :twothumbsup:
73TopBanana
thanks, does anyone have a photo of the 2nd option?
There's no such thing as the two groove fan pulley  :alan2cents:  let me rephrase, E-bodies never used a two groove fan pulley   :unbelievable:
73TopBanana
anlauto, thanks, am using the same 2 groove alternator and installed the new bracket kit. do you have any photos of a small block with no a/c showing the alternator, fan pulleys and power steering pump?
thanks
73TopBanana
I assume you have a small block  :notsure:
73TopBanana
anlauto, saw one on year one website, am i looking at the wrong thing?
73TopBanana
yes, small block, thanks
73TopBanana
Which one should be used? From yearone
Wish List
Part Number: MJ118
Price: $245.22
Reproduction 2-groove crank pulley and 1-groove water pump pulley set with black finish. The following dimensions from the front of the water pump pulley mounting flange to the front of the vibration dampener are required for proper pulley alignment:
Small block: 4-17/32"
QTY:
1
Add to Cart
View
remove from list
Part Number: MJ102
Price: $136.11
Reproduction 2-groove crank pulley with black finish. The following dimensions from the front of the water pump pulley mounting flange to the front of the vibration dampener are required for proper pulley alignment:
Big b
QTY:
1
Add to Cart
View
remove from list
Not very good but it's all I could find
73TopBanana
ANLAUTO, those are just what i as looking for. i thought the power steering belt went over the upper pulley not the bottom one.
Thanks and have a good rest of day  :unitedstates: :canada:
