340 exhaust manifolds
Started by nsmall, April 26, 2017, 10:26:06 PM
nsmall
Is there a difference between 318 and 340 exhaust manifolds?
I have a 1973 340 and I was told I may have 318 manifolds.
If there is such a thing as a 340 manifold I'm assuming it offers more flow than a 318?
There are some 340 manifolds on eBay and they're claiming their high performance but I'm assuming all of them are considered high performance as 340s are more of the High Performance Engine....Right?
71 & up 340 manifolds are not the same as 68-70... 71 & up are more of a log design.. 68-70 are considered the Hipo manifolds.. I just looked on Ebay
& didn't see any 68-70 manifolds
6bblgt
1973 e-body 340 casting numbers:
RH = 3418623 (part # 3418624)
LH = ?? (part # 3751083)
1973 e-body 318 casting numbers:
RH = 2843953 (part # 2843966)
LH = 3512077 (part #3512076)
what casting numbers do you have, got pics?
Port openings are considerably larger for the 340.
I had 340 J heads on my 318 in the past with 360 ex manifolds. California smog check nailed me long ago and I had to remove heads and put my old 318s on. I left the 360 manifolds on and flat area on the 318 port openings barely went as far as the opening on manifolds.
Visually not much difference in 1973, but port size, yes 340's are larger. :alan2cents:
CudaMoparRay
Great info as have been debating taking off my Hooker Competition headers and replacing with OEMish exhaust manifolds.
nsmall
@CudaMoparRay
Sounds like 68-70 OEM manifolds are what we want.
CudaMoparRay
nsmall
moparmadman69
Quote from: nsmall on April 28, 2017, 07:50:25 PM
@CudaMoparRay
Just remember if you run the 70 HP manifolds you have to use a 90 degree oil filter adapter to fit that right manifold. Left there is no clearance issues.
Colby
rocketresto
Shakerhood.com and Northwest Performance is the actual maker of the manifolds and we do not charge Year One shipping prices.  Our retail price is $600 a pair - give us a call if you want to order them.  360-943-6633
Rocket Restorations
Olympia, Washington
CudaMoparRay
Quote from: rocketresto on May 01, 2017, 04:32:06 PM
Extremely tempting
rocketresto
Rocket Restorations
Olympia, Washington
