" HELP " i pad experts PROBLEM SOLVED
Started by Roadman, October 31, 2017, 02:07:54 PM
Roadman
    Been trying to get my ipad to connect to my hotspot on my puter.   :pullinghair:  Did everything I could find on google, no luck.  Any ideas.   :notsure:  I reset the ipad, reset my puter, did a hard reboot.
DAYLEY/CHALLENGER
Can your iPad see the wifi broadcast name?
Roadman
Quote from: HP_Cuda on October 31, 2017, 04:13:35 PM
yes, i put in the password, but the wheel keeps spinning. frustrating. I tryed everthing.  :pullinghair:
Try cycling your hotspot, looks like you are hung up on the WPA password.
Roadman
Quote from: HP_Cuda on October 31, 2017, 05:09:56 PM
                K, will try.  Thx.
lulurocks(Ken)
1.
Have you tried connecting with another device to  eliminate the hot spot .
2.   Some hotspots are sensitive to the ios version the ipad is running , if the ios is to far back it might not allow it .
3.
Open wifi connections in ipad  , next to you hotspot click the (i) and forget the network .
Then coldstart the ipad and try again.
4.  Last resort !!!!!! Clear all network connections ( you will lose all wifis you hook up to and will need to put passwords back in to access them !!!!!  Last resort.......
Settings -general- reset network connections    Ipad will restart .
Try and connect again....
Just stuff ive had to do over the years ......
Good luck
Roadman
Thank you @lulurocks(Ken)  I will run all that stuff tomorrow.
Roadman
 After trying everything, a friend recommended putting the i pad in airplane mode, then out of airplane mode, and trying again. BAM, it worked.   :rebelflag"
Spikedog08
I probably would of suggested that you tell the ipad to forget the network and then try again.  That typically works for me.  Glad you figured it out!
