instruments specialties black suede interior paint
Started by realn96, November 04, 2017, 02:32:34 PM
realn96
My question to everyone is, Has anyone used their suede dash paint that they sell ? Its the lacquer made by ppg..I bought the paint from them and finally getting to it now. I bought the correct dtl16 ppg thinner . Sprayed all the interior parts on top of epoxy primer and it feels like to much texture to me? I don't know if that's correct or not? Your thoughts?? :popcorn:
6bblgt
what car & year are you working on - just the metal parts of the dash/column get sprayed with the suede paint
E-bodies seem to have less texture than 1968-'70 b-bodies
I used it on this '69 RR dash & happy with the texture, not sure if the same texture would be correct for an E-body or '71-'74 B  :dunno:
realn96
71 cuda  And yes just the metal parts you mentioned I am painting with the suede paint.  . color is black. I took another look at it and it must be correct/ I never used it before so I am not familiar with it. Just seems like maybe too much texture? thx for the reply
@realn96  the Suede paint can be a bit tricky to paint.  If it's not done right it will end up having to much texture.  Check out video #3 at about 12:00 minutes in.  I go over the correct way to spray it.
https://www.e-bodies.org/videos/
Convertcuda
Cody I'm trying to find that 3rd video in. Is it still on your site?
Thanks Ken
Quote from: Convertcuda on November 04, 2017, 07:14:59 PM
Thanks Ken
It's in the link above and on YouTube.
realn96
Thanks Cody. That's exactly what I needed to see. I found out that when I went  heavy with the paint I liked it better. .  I really wasn't sure if the paint had too  much texture in it because it was so  ruff if you don't go a little heavier.. thx again !! :thankyou:
Convertcuda
Thanks I got it Cody. Great Video!!!!!!!!!!!!!!
Ken
Convertcuda
I forgot to ask. What tip size on the gun? And what pressure at tip when you spray? How big of fan pattern.
Thanks Ken
I run an RP so it's different then normal HVLP guns.  The pattern is pretty much normal wide fan just like painting cars.
Quote from: Convertcuda on November 05, 2017, 04:30:08 AM
Thanks Ken
realn96
One last question,does the inside of the glove box her paint the suede  black or just semi black? Thx
The glove box is cardboard.  The door is suede (front and back).
