avatar_cuda hunter
How to unlock a cuda
Started by cuda hunter, July 03, 2019, 10:27:28 PM
Quote from: ec_co on July 04, 2019, 09:39:05 PM
when I picked up the Barracuda dad had lost the keys long ago. brought out an old school locksmith and for $120 I had a set of door keys. it was pretty cool watching a master at work. he would hand wiggle a tool in the lock mechanism and hand cut the key, took him a few tries and about 20 min. saved me from having to re-key the column too
Best choice , I did this all my life ...
Optional , if you pull the steering wheel & crush can & remove the lock plate there is a small pin to depress & the ign lock will slide out & have a code on it as a second option
aussiemark
Yes, the ignition lock does have the key code stamped on it , I took one to a locksmith and he cut the key in 5 minutes so I can now keep the original satin finish lock rather then having to settle for the polished Taiwanese junk.
How did you make out C H ?
cuda hunter
Found a key.
I'll post up a barn find for the whole thing when I get a few minutes sometime in the next week.
Well: That was taking the easy way out.
cuda hunter
the owners mom's boyfriend only tried to open the drivers door.  It was locked.  Luckily the passengers door was unlocked.
3 sets of keys.  sitting there where Steve @Bluespruce left them in 1988.
 :haha: Well at least we had some good suggestions.... :cheers:
That is the easiest way , exhaust all options first !!
cuda hunter
Quote from: anlauto on July 19, 2019, 07:29:53 AM
Of which I really appreciate the help.  Thanks guys!   :ohyeah:
