Replacement Fender Tag
Started by 6pack, April 15, 2025, 11:48:21 AM
6pack
I am having a replacement tag to place on my car since mine is in very bad condition.
The guy on here making plastic tags has used my original rusty tag, bad condition build sheet and a paper with codes given to me by the prior owner.This is for my 1971 Challenger pace car.the tags in red are what he created. Any help proof reading it would be great so he can make any changes before making it.thanks Jimmy
avatar_6bblgt @6bblgt  would be the person I would look to.
6pack
ec_co
Everything seems correct to me except for the sequence number, which I can't quite make out. alignment seems correct per other '71 JH 'verts. Please correct me if I'm wrong, I want to make sure we get it correct.
cuda hunter
 6 @6pack
Could you please post several pictures of the rotted sequence SPD area of the tag?  Different angles, different light.  Please also post pics from the rear of the tag.
  Also can you post close ups of the small piece of the BS and the top few lines on that broadcast sheet?
Everything else looks appropriate to me.
6pack
Hi Cuda Hunter, I looked at the small piece of paper that broke off on the build sheet and figured it out. Thanks for looking. I will be bringing this car to Carlisle this year. So you can check it out. See you there.
6bblgt
Quote from: Cuda Cody on April 15, 2025, 06:42:23 PMavatar_6bblgt @6bblgt  would be the person I would look to.
I made a comment on facebook about the Sequence # not being the same as the VON, but since it doesn't look like an actual VON will be available  :thinking: using the Sequence # is not a bad idea ????
ec_co
My bad, I meant VON. He was able to decipher that little torn corner to get the VON, so we have a complete one to recreate now.
6bblgt
what or where is the VON you figured out?
ec_co
Quote from: 6bblgt on April 17, 2025, 09:36:24 AMwhat or where is the VON you figured out?
You can see a hint of it in the upper right corner of the build sheet picture (or am I reading that wrong?). I have a better close up and in person he was able to get the number. I'll let him comment if he wants to share.
Edit: looking at the build sheet page, looks like I was wrong and that's the number before the VON, which does seem to be missing.
Jay Bee
I wonder if Dave Wise from MMC Detroit would have that information, no harm in asking. I sent him my VIN and asked for any information, sadly he had none on my car.
https://www.mmcdetroit.com/
