avatar_nsmall
15 inch non factory wheels, tires, center caps, trim rings
Started by nsmall, April 03, 2018, 11:05:10 AM
nsmall
I'm assuming they are 15x7s
I can't find any factory stampings so I'm assuming that they are reproductions.
Is $500 for everything including some used lug nuts reasonable or should I expect less?
Center caps are OEM, assuming trim rings are reproductions.
nsmall
I'll bring them to the spring fling on Sat.  Will $500 sell this set?  Can I ask for more?
Crocha617
If they are really 15" with good tires $500 should be really easy. If 15x7s I would think even more. A new set of 15x7s from summit with rings and centers will cost you like $725.
If you were close I'd give $500 for them to keep as spares for the next car.
cuda hunter
If they have zero markings on the visible areas of the rims, then I would agree they are most likely reproduction 15X7's.....
I would say a rather quick sale for $500  :dunno:
