avatar_erik70rt
1970 Challenger Manual Disc Brake Swap
Started by erik70rt, July 07, 2023, 06:50:29 AM
erik70rt
Has anyone over done this?  I am swapping to a stock style setup with the kelsey hayes calipers.  The specific question I have is that when I swapped out the master cylinder from drums to discs, the brake pedal now sits a few inches higher than it did.  I assume I need to swap out the pushrod to the master cylinder to a shorter one but thought I would ask before making any changes to the pushrod.
Thanks!
Erik
Yes, I always do it now. It seems like I always build basket cases so I've never swapped one out per se but I would just go for an adjustable pushrod if you're having that problem.
I don't see a downside to this swap at all and am not sure why people seem to think they need PB. I used to use a non PB, disc brake, A-body M/C but my last few builds I've used this one.
https://nationalmoparts.com/product/1971-8-b-body-1971-3-c-body-1971-4-e-body-master-cylinder-with-power-disc-brakes/
