70 dodge challenger booster and master
Started by 70rtse, April 11, 2022, 06:46:43 PM
70rtse
Hi guys looking at getting my brake booster and master cylinder overhauled
Not sure if this booster is correct for 70 dodge challenger
The master looks original.
70rtse
 Pics
70rtse
Master
 Your booster appears to be the Midland-Ross booster used 72-74 just painted black.
   First clue is the band clamp that are not used on the Bendix booster.
     Good Cores for both are hard to find from what I'm seeing
Found a decent comparison thread here, about the 10th post has correct '70 booster  http://files.mpoli.fi/The.Dodge.Challenger.Message.Board/challenger.mpoli.fi/board/topic-5442.html
Those parts you have will work, but as mentioned "not correct" for 1970. :alan2cents:
70rtse
Can you buy reproduction brake booster and master that are correct
JH27N0B
By correct do you mean OE appearing reproduction parts?  If so, no.
If you mean correct in that they will work, sure.  The original one year only 1" bore master for 70 E bodies is very hard to find and expensive if you do find one, but the one you show, Raybestos MC36283 works and has a 1-1/8 bore, the MC36307 works and looks a bit closer to original and has a 1-1/32" bore.  Paint it black before installing for a closer to original appearance.
340challconvert
Pic of an original 70 booster unit
and the "thermometer front" disc brake master.
Banana
Guys, for the Master Cover and Wire Clip, both are painted the same black as the master body and booster correct ? As shown in your reference picture.  Sometimes I see Master Covers as Yellow Zinc/Cad plated and not painted black
In 1970 it's fairly safe to say that ALL E Body power brake booster/master cylinder assemblies were painted complete black. They were delivered to the assembly plants by Bendex as an assembly, so everything was painted as one....cap and bail wire....everything.
JH27N0B
Disc brake masters were painted completely black.  I've never seen any evidence of drum brake master cylinders being painted black, regardless of whether they were on a manual or power brake equipped car.
70rtse
Are the brake boosters the same for 70 disk brake and drum brake front end
Obviously the master cylinder are diffrent?
6bblgt
Quote from: 70rtse on January 11, 2023, 05:04:54 PM
YES  :yes:
70rtse
Thanks I think I have found one
Will the master cylinder I have work with the 70 booster.
