avatar_edison1970
Dot 5 fluid
Started by edison1970, November 11, 2020, 06:24:22 PM
edison1970
Does anyone know if there is a compatibility issue with using Dot 5 in our older brake systems?  I had to put another master cylinder on my car because the seal on the back where the rod goes was leaking . This is the second one.
cudaize
I have DOT 5 silicone fluid in (2) of my 71 Cudas and my 70 Challenger and have not had any problems.  I did these when I replaced all brake components as the DOT 5 does not mix with the DOT 3.  If your system has fluid in it you can bleed it out.
The only problem that I have seen is that the silicone fluid ruins the brake switches that are actuated by fluid.  My father goes through about one every year or two on his 58 Fury.  The switches on E-bodies are mechanical so not an issue.
71340RT
I have run Dot 5 brake fluid in my 71 Challenger RT for at least 20 years with no problems and it won't damage paint.
1971 Challenger RT 340 auto 1 of 731
1973 Challenger Rallye 392 Hemi A41 4 speed automatic
2016 Dodge Challenger Scat Pack 392 Hemi auto
750-h2
On a restoration Dot 5 brake fluid is the only way to go. If you have a leak or spill it will NOT harm the paint. :clapping:
Jay Bee
My car's had DOT 5 SILICONE in it since 2011 with absolutely no problems or issues. The master, all the lines and wheel cylinder were replaced first.
Dot 5 in all my restorations  :twothumbsup:
floorit426
Can you change from DOT 3, to DOT 5, without dismantling your brake system?
edison1970
Sounds like the answers I was hoping for.  All of the brake components are new on my car. Maybe just poor master cylinders.
mopar jack
Quote from: edison1970 on November 11, 2020, 06:24:22 PM
No leaks at the back but have had a couple disc brake master cylinders leak internally where the front wheel reservoir(the large one) level would go low and the rear wheel reservoir would go high and start to spill out the top.
Personal/professional recommendation. Never use a rebuilt master cylinder, always a high quality, new unit only. Rebuilt M/C's  regularly fail at a much faster rate than new. It only has to fail once....
Quote from: floorit426 on November 12, 2020, 07:03:48 AM
You need to flush it thoroughly first.
FSHTAIL
Quote from: 750-h2 on November 12, 2020, 06:20:37 AM
That's what the body shop recommended as well just because of the paint..
Quote from: dodj on November 12, 2020, 12:32:58 PM
I have read "no, you cannot change."
Something to do with how the seals respond to one of the fluids that they need to be new.
I've not tried it.
I just got my master cylinder back from White Post Restoration's with a installation sheet and a lifetime guarantee but void if using dot 5 brake fluid. So many different opinions on this . The only plus I see is that it won't hurt the paint if you have a leak.
rocketresto
Make sure the master is compatible with Dot 5.  Have had several fail here with the "correct" repo drum brake master cylinder.  Know Dot 3 can kill paint but seems like every time we run Dot 5 is either leaks or the master fails.  Only run Dot 3 now.
Rocket Restorations
Olympia, Washington
