avatar_Dakota
Is the brake booster pushrod adjustable? (70 Challenger)
Started by Dakota, November 14, 2020, 06:00:51 PM
I have a little too much travel in my brake pedal before the brakes kick in.   The brakes work great once that point is reached.   I have the same booster as what's shown in this picture that Cody posted a while back.
edison1970
Yes. It is adjustable.  Be careful not to go too far. The brakes will drag.  I have the same issue with mine.
Quote from: edison1970 on November 14, 2020, 06:26:59 PM
Here's a question about this...do you think it's possible for the rear brakes to "drag" and not the front brakes if this rod is adjusted incorrectly ?
Keep in mind the reservoir for the front brakes is closer to the booster ...
edison1970
I'm not sure about the answer to your question but I adjusted the rod out too far and about a quarter mile from my house, I  had to pull over and readjust it. I pushed in the clutch and the car came to a halt. Front brakes were smoking.
The front brake reservoir is closer to the firewall so it is more likely that hte front brakes will drag , I can't see the rear brakes dragging without the front as the piston for the front brakes has to move to activate the rear brakes .
Quote from: Chryco Psycho on November 14, 2020, 11:15:01 PM
That's what I thought too, thank you. :drinkingbud:
VCODE
Dakota, there is a tool made for getting the correct measurement. About .030 between push rod and piston clearance.
Bob
Incorrectly adjusted rear brake shoes will cause a low pedal also.  The shoes should have a slight drag on the drum when they are adjusted correctly.
As for the booster pushrod...
I measured the distance from the master cylinder mounting flange to the bottom of the master cylinder piston.  Then I adjusted the pushrod to match this measurement.(from the tip of the pushrod to the booster mounting flange)  Once the gasket is installed between the two parts and "crushed" you'll have a little bit of clearance.  Right or wrong, that is how I did it.
Thanks for all the replies.
I made a rough adjustment this afternoon.  Much better!  Best I can tell, there's no drag.
I will probably get one of the measuring tools to make sure it's correct.  Since I didn't want to disconnect the brake lines from the master cylinder, there's not a lot of room for my caliper.
I was pleasantly surprised at how easy it was to adjust since the pushrod can be partially removed from the booster to get better positioning with the tools and the coiled brake lines provide a bit of "give" for moving the master cylinder.
Cuda_mark
Quote from: VCODE on November 15, 2020, 07:23:38 AMDakota, there is a tool made for getting the correct measurement. About .030 between push rod and piston clearance.
Bob
V @VCODE  Can you let me know what this tool is? I might need it.
VCODE
mtull
Cuda_mark
I ordered one and I'm going to try to measure the MC and booster while they are still in the car.
