avatar_mopar jack
moog lower control arm bushings
Started by mopar jack, April 02, 2020, 08:41:30 PM
mopar jack
Quote from: Jocigar on April 03, 2020, 08:21:31 AM
Since I have a lathe I ended up knurling the pins.
I ordered my parts from summit and all of the front suspension bushing were off.  some I corrected, the remainder I reordered until they fell in spec then returned the rest.    They were made in different countries, but I don't think there was a correlation with good parts and where they were made.
I guess moog doesn't own a pair of digital calipers  :dunno
https://forum.e-bodies.org/wheels-tires-brakes-suspension-and-steering/12/lower-control-arm-pivot-shaft-70-challenger/10978/
Well I've  ordered and returned 4 bushings. I thought about adjusting the pin but I don't have the equipment.
RealWing
1969 Barracuda 340S fastback
1969 Barracuda 6.1Hemi restomod convertible
1970 Superbird 440-6bbl
 :welcome: @RealWing  You should go to the new members section and introduce your self.  :handshake:
Mopar5
I had a similar issue with loose moog bushings on my OEM pins. It took very little force to press them in. I ordered new pins from PST and they worked perfect with the same bushings. I assumed the bushings were at fault but it turned out to be the pins which is strange because the pins dont seem to be a wearing item which would reduce the diameter. :thinking:
Wow. I guess I dodged a bullet when I replaced all my front suspension's bushings with Moog 3 years ago.  Everything fit fine then.  :)
wanderlustin
Hi guys.  Has anyone purchased Moog LCA bushings lately?  Curious of the fitment issue has been resolved.
