avatar_nicka
Power Brake Booster
Started by nicka, July 02, 2021, 07:49:46 AM
nicka
I'm trying to identify the manufacture of this Power Brake Booster.  My car is a '71 Barracuda disk/drum  and a late build: von: 628
After reviewing the threads on this site, I'm guessing its a Midland Ross?  I noticed the band type clamp and looks like some type of cad plating.
Floyd
Believe that's a Midland Ross unit.  Correct for most 71s (some early cars had the 70-style Bendix units).
Band holding the two halves together = Midland Ross
Two halves crimped together =Bendix
nicka
Manuel
Yes, Midland Ross.  Exactly as the one on my 71 Cuda.
Got here the name of BOOSTER EXCHANGE as a shop for them.   Those guys exceed anyone expectations.
Floyd
Quote from: Manuel on July 03, 2021, 01:38:03 PM
Yep, They did one of those for me and it turned out great.
http://boosterdeweyexchange.com/
nicka
Yupe.  A member posted a pic of a power brake booster redone by them.  The member also mentioned removing the surface scratches before sending it in.  Good to know.
Thanks again.
Mrbill426
@nicka  Yes the more you clean up the surface ahead of time the better the end result will be.  Mine was pretty rusty (pits too) so I soaked it in Evaporust which is nontoxic and works very well; if you go that route remove as much loose scale as you can first, and ANY grease/oil too.  The stuff will not remove paint so get any off too.  I used conditioning discs to smooth out as much of the pits and scratches as I could.  If you are having it plated any of that will show so the smoother the better.  If it will be painted not as big a deal.  When I sent mine in to the Booster Exchange they said about 6 weeks turnaround... it was.   You can call them with questions, they are really nice folks.
Quote from: nicka on July 03, 2021, 02:25:28 PM
Thanks again.
