Quiet vacuum pump for big cam motors with power brakes.
Started by Roadman, February 12, 2017, 02:45:32 PM
cataclysm80
Do stroker engines typically have big cams and vacuum problems?
chal340
I put this hydrauboost from Hydratech on my Challenger. Very nice product and very nice service.
A buddy put a diesel vaccum pump because he don't have power steering. He made some brackets and installed it in place of the power steering.
70 Dodge Challenger 340 A66.
chal340
Another solution, put an alternator vaccum pump. You can find them in all diesel japenese cars.
61K T/A
Quote from: HP_Cuda on February 15, 2017, 04:39:25 PM
I may have to go this direction but would like to mount it in the engine bay somewhere and not worry about longevity issues.
:lurking:
That was my concern too (longevity) but then I thought about adding a shield to it. This is just to prevent road debris form directly hitting the pump. I did this to one of my trucks when the fuel pump cam lobed got wiped and then installed an elec. fuel pump to the frame rail adjacent to the front tire. I use some scrap aluminium diamond plate and worked out well.
I never did go that route since I decided to install a Hydoboost system.
Yeah I was thinking that as well but the guy who sells them also says to keep them away from heat.
So building a shield could also potentially turn it into a heat sync. I'll have to play around with placement and see.
Quote from: 61K T/A on February 16, 2017, 03:03:40 AM
:lurking:
MoparDave
we put one of those hydroboost on this one with a 472 crate hemi
The stroke will not have much to do with it as much as the cam design.  Big cams will cause the problem.  :alan2cents:
Quote from: cataclysm80 on February 15, 2017, 11:58:19 PM
Long duration cams and to a lesser extent overlap kills vacuum.
When the piston is headed do a intake downstroke that is where vacuum is made. The four cycles are intake, compression, power and exhaust.
The duration holds the valves open longer and somewhere near the apex overlap happens where both intake and exhaust are open. The good part is that it creates more power the downside is you lose in the vacuum department.
chal340
The Hydroboost in my Challenger. I put black hoses between power steering pump and the Hydroboost.
:lurking:
I mounted a vacuum pump in the trunk of my '71 and hid it behind the battery.  Again, this was a very loud pump and I would suggest another alternative.
Another vote for hydroboost  if you have power steering anyway this is an easy addition
cataclysm80
You guys make the hydroboost sound pretty good.
I'm still fond of the way the original disc brake master cylinder looks though.
Tough call...
I need to figure out what front disc brake setup I'm going to run .
61K T/A
Quote from: Chryco Psycho on February 17, 2017, 07:11:54 PM
My car was manual steering. The bracket and pump install was easy. Just had to make sure I bought the right pump. The pump on average needs to out 1300psi.
chal340
Quote from: 61K T/A on February 18, 2017, 04:30:34 AM
what's the average of the stock pump?
61K T/A
The Hydroboost unit loves pressure *(up tp 2600psi). If your running both power steering and brakes and a low pressure pump you will not have any advantage from a HB system. The maximum benefit from the unit would be running a pump rated for 1350psi. Any higher and you will blow your seals. The pressure drop from the prop valve to the rear brakes is significant. So if your running low a pressure pump you might as well stick with a vacuum booster.  :alan2cents:
