normal_post in stock front height in Wheels, Tires, Brakes, Suspension & Steering Author Topic: stock front height  (Read 690 times)
Offline culp71
  • Trade Count: (1)
  • Small Block
  • index in stock front height in Wheels, Tires, Brakes, Suspension & Steering
  • Credits: 1140
    • Share Post
xx in stock front height in Wheels, Tires, Brakes, Suspension & Steering
stock front height
« on: May 22, 2018, 08:35:27 AM »
what is the approximate ride height for the front on a 71 cuda w 340?
right now the head of the torsion rod adjustment bolt is about even with bottom of LCA sides.
I am dialing in front alignment but want to verify before I tighten all.
Linkback: https://forum.e-bodies.org/wheels-tires-brakes-suspension-and-steering/12/stock-front-height/6945/
« Last Edit: May 22, 2018, 08:46:34 AM by culp71 »
Offline mopar jack
  • Trade Count: (0)
  • Small Block
  • Credits: 1340
    • Share Post
clip in stock front height in Wheels, Tires, Brakes, Suspension & Steering
Re: stock front height
« Reply #1 on: May 22, 2018, 08:48:18 AM »
i recommend you use the factory procedure to set ride height.
Offline culp71
  • Trade Count: (1)
  • Small Block
  • Credits: 1140
    • Share Post
« Reply #2 on: May 22, 2018, 09:18:24 AM »
alright cant make out that font clearly...but does it say in short:
Blade must be higher from ground then ball joint, e body 1 inch plus/minus inch? 1/8 inch? cant make this part out...
and well over an inch clearance over lower arm bump stop.
not very clear or specific that's for sure...
maybe a better question is with all stock, what should be the space from hub center to fender lip?
I understand that it can be lowered and realigned to suit the look most want. but again looking for stock spec.
I did find this of an unrestored cuda, since tire size and wheel are the same I will use it and set my car similar.
and it does appear front is a touch higher then rear.
« Last Edit: May 22, 2018, 10:26:19 AM by culp71 »
Offline HP2
  • Trade Count: (0)
  • Big Block
  • Credits: 3430
    • Share Post
« Reply #3 on: May 22, 2018, 10:12:55 AM »
The OEM setting on an E body  is with the blade measurement 1.125" +/- .125" higher than the ball joint measurement. There is no factory measurement of fender lip height due to variety of tires sizes that can influence this measurement, hence the control arm measurements which are consistent within each body line regardless of tires.
Doing it this way may result in a nose up appearance, again, depending on what your tires sizes are.
Other factory specs, fwiw:
Camber
     left  0 to +1 degree
   right   -1/4 to + 3/4 degree
Caster
    power  -1/2 to +1 3/4
   manual  -1 3/4 to +1/2
I would only suggest using stock specifications if you are using original sized bias ply tires. if you have radials, you can utilize more aggressive numbers to improve the performance of the car.
Offline RUNCHARGER
  • Trade Count: (6)
  • E-Body Wizard
  • Credits: 14040
    • Share Post
« Reply #4 on: May 22, 2018, 07:41:14 PM »
To me that orange Cuda sits right and looks stock. I used to do the blade measurement but haven't for years. I measure the front and rear of the rockers now as well as the tops of the wheel openings. Sure it wasn't what the factory did but these bodies aren't always square and I find the blade settings may result in one side of the body being higher than the other.
Offline culp71
  • Trade Count: (1)
  • Small Block
  • Credits: 1140
    • Share Post
« Reply #5 on: May 29, 2018, 10:30:59 AM »
I got my alignment and suspension all setup and mimicked the orange one and it seems right, looks great should handle well. soon find out. :banana:
Offline culp71
  • Trade Count: (1)
  • Small Block
  • Credits: 1140
    • Share Post
« Reply #6 on: August 10, 2018, 06:35:55 AM »
So I got it all set, and it rides perfectly, great handing and looks awesome.
with all correct stock parts and properly rebuilt, (with correct 340 and E60-15 polyglas tires)
the ground to fender lip is 26 inches in the back and 26 1/8 in the front, just in case
any one else is trying to get there's to have that stock look.
just turned over the first 300 miles!
Offline RUNCHARGER
  • Trade Count: (6)
  • E-Body Wizard
  • Credits: 14040
    • Share Post
« Reply #7 on: August 10, 2018, 03:50:24 PM »
Yes: I personally think they drive quite well stock for how old the design is. Feels great to drive them after working on them for so long doesn't it?
clip
Height of body
Started by chal340
Last post April 10, 2017, 12:35:01 AM
by chal340
xx
340 Fan pulley height on a/c &P/s car
Started by BuzzBusby
Last post April 05, 2018, 03:24:24 PM
by BuzzBusby
xx
Ride Height and Camber
Started by gzig5
Last post July 07, 2018, 06:08:44 PM
by gzig5
xx
Car Height on Build Sheet
Started by Cuda Cody
Last post March 06, 2017, 03:12:12 PM
by Cuda Cody
xx
1970 Cuda ride height
Started by jamesroney
Last post June 07, 2017, 02:18:33 PM
by HP2
