Stock sway bar 70 Challenger
Started by Mopar5, January 29, 2019, 01:18:53 PM
Mopar5
Hello,I forgot to mark my sway bar when i took it out . My question is which is the up and down side of the sway bar,or is it just going to be obvious when trying to install it . I was looking at the radius of the ends where the links attach and it does appear to have side that should be up just don't know which it is. Thanks
Mopar5
If you look at the sides of the sway bar you'll notice a slight curve. When properly installed that curve will be a "frown"  :( not a "smile"  :smile: if that makes sense. :alan2cents:
Mopar5
Beautifully worded makes perfect sense Thank you
I doubt a rear bar would go in upside down the center would hit the diff
