70 RT Challenger 440 4 speed U code Dana in FJ5 - Restoration
Started by horse, March 30, 2018, 02:08:51 AM
horse
Rear end update:
Trunk floor coming together. Spot welded as much as possible. Remade jack brackets etc. Made a drain for bottom of pillar to allow moisture to escape.
Back to blasters shortly and epoxy before rear quarters going on. Trying to replicate the factory under seal on quarters and paint panels beforehand.
Looking good, it's nice when they are going back together.
Morty426
horse
Wow these restorations drag on.
A few more pics....getting closer to a complete body now.
Outstanding work there.  Love the color!  If you don't mind what is your 512 engine build going to consist of?  I also have a 512 stroker in my '70 'Cuda.
And  :welcome: from Utah.
horse
Thanks. Nice place Utah
Sure the 512 consists of:
Diamond forged pistons
Eagle 4.250 crank
Eagle 7.100 rods
Stud girdle
Jones cam design roller cam
Hughes 1.6 roller rockers
Chad Speier Edelbrock CNC heads
Holley Street dominator
950 CFM carb
Firecore ignition
Made 652hp at 5700rpm
horse
Cheers guys.
Can someone tell me if the 4 speed tunnel looks correct with this overlap
Ifixmycarmyself
Very nice and inspiring work! How is it proceeding. One question, was the quality of the panels so good that you could just weld everything together without using self drilling screws and test-fitting quarter panels together with inner wheel housing and rear panel, 10 times as i have to do :)
horse
It has been slow due to other commitments sadly.
It is basically almost ready for paint and going to get in to it soon so will update then.
In regards to your question, a few pieces needed a little massaging but overall things fitted very well straight off.
