Door glass help needed - 70 Challenger
Started by GerryThal, July 23, 2020, 03:19:18 PM
GerryThal
I am in need of help with assembling the door glass in my 1970 Challenger. I took the doors apart 3 years ago, and I did bag the parts, but dont recall the placement. Thank you so much for your help!
Picture #1:
Please let me know if the "door glass stabilizer" (correct term??) needs new rubber & is the rubber "flocked"? Mine are in OK condition... Also, do you put any lube in the channel?
Picture #2: are these the upstops for the door glass? Where do they go?
Your part looks fine....I grease the channel up. The two up stops are from  72-74 Door and mount to the inside of the door you should see slots and holes where they go
Picture 1 - the rubber looks OK
I usually use white lithium on the slides for lube
Picture 2 - yes those are up stops on the doors they bolt to the inside upper lip , there are also similar brackets to position the glass inward that have felt on them .
I have a 1971 Cuda in the shop right now with a 1973-74 door on one side only, complicates things because all the window hardware is totally different including the up stop locations.
Here's where they go, one at the front, and one at the rear obviously
GerryThal
Thank you SO much for the help guys!
This is a 1970, but I am now wondering/thinking that the doors are from a different year?
This may explain why I have different hardware for each door....     :(
I will check both doors tonight, and update.
Thank you again for your advise !!  :bigthumb:
I'm 100% certain those up-stops are from a newer door.
GerryThal
Ok, here are pics of both doors - they are different :(
so this means I will need different hardware for each door?
do the both use the same type guides?
Jay Bee
Can't answer the guide question, what I can tell you is that the passenger side is a 1970 one and the driver side is a 1971 and up.
GerryThal
Thank you for identifying the doors - the passenger side is missing the guides and upstops - thats why I was wondering if they take the same hardware = looks like the upstops will be different??
JonH
driver side front and rear up stops 70 Challenger
There are plenty of differences, but I believe you can make everything from a 70-71 work inside a 73-74 door with the EXCEPTION of the up-stops.
The main difference is the width of the front track. :alan2cents:
RJChallenger
1970  window regulators will not work in a 71-74 style doors . The window will not completely go down. The later style window regulators will work in all doors.
That's an interesting point Rob that I never thought of
Jay Bee
Quote from: RJChallenger on July 25, 2020, 08:25:03 PM
That only applies to Challengers. I have a 1970 regulator in my '71+ right side door. Somewhere on this forum I went through an explanation as to why that is.
GerryThal
Thanks again to all you guys for the help!
These are the guides I purchased - I dont believe I have any like the short ones - both of my doors seem to take the "long" guide in the front, so I am assuming the short guides go in the back? Does anyone have a photo of the guides in place?
