avatar_70_440-6Cuda
HELP! Sheet Metal Repair Advice Needed
Started by 70_440-6Cuda, December 08, 2025, 08:11:00 AM
CUDACRAZY, Marty, camarochevy1970 and 2 Guests are viewing this topic.
70_440-6Cuda
Ok, so it just keeps getting worse.  I have gone from a trunk floor replacement to everything from the 1/4 panels back except the tail panel.  Uncovering the WORST hack job body repairs I have ever seen.  Bondo is the least of the problems.... Rust not even cut out, just stuffed with everything and anything and then up to 1/2" if body filler.  We found hot glue - yes, hot glue - and welding wire used to hold the rear window trim in place.
So the latest and greatest?  In prepping to do the 1/4 panel swap, we found the C pillars full of holes, stuffed with tin foil and bondo.  Nothing to weld to.  A pillars aren't any better.
My fabricator said the for the hours it would take to patch and repair the areas to be able to have anything useable, he can install a roof skin and suggested that is the way to go.
That seems a little extreme, wanted to get some thoughts form the group as I am no expert. We don't have ALL the paint off the roof so don't even know if it is going to get worse.
His reasoning is he has to get the 1/4s under the roof skin so it all has to come apart very carefully, but there is no integrity and the seam, so it is going to be a giant mess, and then fabricating replacement panels and making it perfect is more work than it is worth.  For me the C pillars don't look so bad, but I am no metal fabricator.  His point is he can hack off the lower section of the roof at the 1/4 panel, and get all of the wheel wells, trunk and 1/4s installed in one go, and then skin the roof easily.
At this point, I feel like maybe having all new sheet metal from the doors back including the roof may be a value add?
Good money after bad at this point, but I am too far in now and what are the options?
Thoughts?
340Challman
oof! Yeah, I think I agree with your body man. There is definitely a point where it is cheaper to replace and then deal with poor reproductions than trying to repair. Fab time can quickly get expensive. I didn't have to do a roof skin, although with all the work that went into making the roof look good, I probably should have. I did replace the A pillars. Mine weren't as bad as yours, but it still made sense.
I have not seen one or heard anything from anyone about the quality of the AMD roof skins, but I think I would look into it. The skin is only $550. Shipping will hurt, but it may still be cheaper in the long run. Be prepared for this scenario to repeat itself over and over. I thought I had a fairly rust free car. Mostly exterior metal. That turned out not to be the case. It hides everywhere. One thing I know for sure, it doesn't make any sense to spend the amount of money and time as a restoration does to leave rust behind. You have to get it all or at least stop it to the best of your ability/pocketbook.
Good luck.
Kevin
Must have been done by the same guy that worked on mine. The more I dug, the worse it got until I just pulled the trigger on a Dynacorn rear half kit and replaced full floor, RH rockers, A pillar, door frame, and half the upper cowl.  Not to mention the full quarters and roof skin that I knew needed replacement.
 If you are paying for the labor, panel replacement is a lot less expensive in most cases than fabbing/shaping/splicing multiple patch panels. Just doing the Dynacorn unit saved a ton of labor over doing it in individual pieces.
The way I look at it, I'm not in this to flip the car and make money.  I need it to be solid and safe for the track events I plan on doing.  I'll probably be upside down at the end of it, but I don't care.  It will be done right and the way I want it done.  Still, it should cost me less than what I paid for my 2020 Ram truck depending on what I do for paint.
ebodyproducts
Buy the AMD A-Pillar skins, unless the inner and outer are gone.  Roof Skin may be needed.
E-Body Products
www.ebodyproducts.com
606-481-9014
70_440-6Cuda
I am leaning towards A pillars and roof skin, just such a bummer.
I trust my guy without a doubt, but he even said either way, up to me.  Just his recommendation to replace the roof - he said I may save a little bit cost wise patching etc, but the job wont be as nice as doing the whole roof, plus being able to show a quality job with new panels is worth something.....maybe??
soundcontrol
My Barracuda has rust i exactly the same places, vinyltop (maybe yours had a vinyl top before also). I don't know how bad it is but I'll find out when I strip the vinyl, it's very soft on a large area though, and also on the a-pillars, at least no bondo and bad repairs, no one touch it before I got it. For now I'm just driving it, rust and all...
For yours I would go with what your fabricator says, lots of work to patch it up. I might have to do the same on mine.
larry4406
I hope there is a special place in hell for the person that did that.
70_440-6Cuda
Quote from: larry4406 on December 08, 2025, 12:50:18 PMI hope there is a special place in hell for the person that did that.
Right!!!!  I mean, I did some questionable work as a teenager, young adult - but that is a whole other level! Literally installed with hot glue - take a look for your viewing pleasure :huh:
I would fix the roof, however my time is free. It sounds like he feels pulling up the roof will make the other repairs go faster so I would listen to him in your case. Pulling up the roof skin will enable coating the structure and that is a major benefit.
In the emd you will feel much better when driving the car.
70_440-6Cuda
Quote from: RUNCHARGER on December 08, 2025, 01:12:33 PMI would fix the roof, however my time is free. It sounds like he feels pulling up the roof will make the other repairs go faster so I would listen to him in your case.
avatar_RUNCHARGER @RUNCHARGER that was his point exactly, he said it may be SLIGHTLY less money to patch, but felt having new sheet metal everywhere is the better choice - looking for opinions - I understand the "if I did it myself" - unfortunately that is not my skillset.
I guess the main question is there any real value in trying to salvage what is there?  Seems every time he looks more it gets worse - literally started with a center trunk floor - then the drop offs were no good, then the quarters and inner wells will so bad at the seams it wasn't worth salvaging.
I really wanted to keep as much Mopar metal as possible, but that is out the window at this point
ec_co
You said it yourself, you are not a metal working professional. If he's good and knows what he's doing, just let him do it the right way.
ebodyproducts
Maybe when the repairs were done, all of the new metal wasn't an option then.  AMD and other metal has been a game changer for restoring our Mopars.
E-Body Products
606-481-9014
EDL94
I did an AMD roof skin years ago and I was amazed it fit like a glove. No extra fitting just set it on and welded it up. This was 15 years ago so not sure if anything has changed.
70_440-6Cuda
Thanks all!  I rely so heavily on the feedback here - greatly appreciated! Well, I suppose I am ordering a roof and A pillars tomorrow :takemymoney:
tparker
For what its worth, I did my own roof. The vinyl caused the rain to rot the roof, rear window channels, the panel behind the trunk lid, and the trunk floor. I had to replace it all. The roof was pretty easy, but tedious. There a lot of spot welds that need to be removed. I used a spot weld cutter and went through several.Takes a bit of time. Quality cutters would probably work better than the harbor frieght ones. The AMD roof fit perfect. The only hard part was figuring out how to attach the rain gutter. I used eastwood "lead" kit for the seams and it worked great.
I used the two part pan for the trunk since it wouldn't be easy to put the one piece in without major surgery. I f'd that whole thing up. Ugh. I probably should have got the one piece and just cut out the center bit and use that. Then sides where mostly OK.
I'd vote for the roof skin. It's a bit of work but probably as much as patching panels and the final work.
