avatar_Husk Challenger
Dimmer switch
Started by Husk Challenger, October 24, 2017, 07:55:14 AM
Husk Challenger
Hi all!
Dash lights don't work on my car. I read the problem may come from the dimmer switch. (Fuses are Ok, wiring looks good to)
Before order a new one if this one is dead i would to know how i can refresh it?
Any tips to clean it of dust and oxidation?
Thank you!
Make sure the contacts are clean & the coil also , lightly clean with a fine emery cloth ,
if you short the wires do the lights come on ?
If you need a new one JSrestorations is the man to use
Husk Challenger
To short the wires, i connect the blackd and yellows together? Correct?
Sorry for silly question but electricity is really not my cup of tea as you can see...
Roadman
Quote from: Chryco Psycho on October 24, 2017, 08:07:44 AM
                         :iagree:    Member @Slotts
I do not have the wiring diagram here but orange si generally dash lighting , test withh a multi meter one will have power & the other will have resistance to ground through the bulbs
Husk Challenger
Problem solved after a good cleaning of the dimmer witch.
Also fixed wiper glass bug when they don't come back at the good position... Ground issue!
Jay Bee
What I like about his is that the resistance coil is stainless steel.
Congrats on the fixes.
Glad you got it solved !!  :bigthumb:
