avatar_ToxicWolf
High Output Alternator Question
Started by ToxicWolf, May 24, 2018, 07:27:33 AM
ToxicWolf
I know I read about this here before, but no matter how hard I search I can't find it.
I have an electric AC system in my car with a 572 hemi.  I'm looking for an alternator that is putting out more than300 amps that will fit my 70 challenger. I seem to remember about one that puts out 360 amps.  Any input will be appreciated.  :wave:
Brad is running a 250 amp alt as I recall
purple1
Dave
Worlds first e-body trailer. Severna Park, Maryland
ToxicWolf
Thanks Chryco and Purple1.  I'm on it.  Looking at one from Quality Power also 320 amp with 180 amp at idle.  :woohoo:
Holy heck: You are using welding cables for power leads I hope. I don't think semi trucks have that big of an alternator.
good gravy thats a lot of current. EVERYTHING turned on my car only pulls like 68amps [radio, headlights, full blower, e-fan, efi running], I had an inductive ammeter hooked to my 160a alternator.
ToxicWolf
Quote from: Brads70 on May 24, 2018, 07:30:36 PM
here is what I'm running. Happy with it for 4-5 years now....
http://www.qualitypowerauto.com/catalog.php?item=557
Just ordered that one. I need lots of amps to run my electronic AC compressor.  :wowzers:
Quote from: ToxicWolf on May 24, 2018, 08:36:18 PM
I wondered how that was going to work out for you?
What is the benefit you are seeing by running the electric? Do you not have room for an engine driven compressor?
ToxicWolf
Quote from: GoodysGotaCuda on May 25, 2018, 06:27:24 AM
Mostly, I just wanted to keep the engine bay cleaner.  No visible compressor or hoses. The compressor is under the passenger fender and all the hoses are hidden from view.  :lurking:
Quote from: ToxicWolf on May 25, 2018, 12:02:56 PM
I wish you would come to Carlsile so I could check your car out!  :D :Stirring: :pokeeye:
ToxicWolf
Quote from: Brads70 on May 25, 2018, 12:58:43 PM
Me too!  :veryexcited: :cooldance: :woohoo:
The idea sounds neat all right. That should clean up the engine bay pretty good although then you have a big butt alternator.
