avatar_Cratos
hot wire in run only needed
Started by Cratos, June 08, 2021, 07:17:56 AM
Cratos
I am looking for a hot wire, only hot in run position to run ( but not on the acc) a trigger for a relay for my add on gauges, and things. Thanks
The blue wire that comes out of the ignition switch has power only in "run".
Cratos
I have an  ididt tilt column and the wires are not the same. looking for something under the dash ,that I can jump off of :)
The blue wire that come off of the + side of the coil has power only in "run".  It goes from the coil, to the ballast, then through the bulkhead connector. Get under the dash and see where that wire comes through the bulkhead.
You can also use your test light and see if there is a fuse in the fuse panel that only has power in "run".
Better yet, get a wiring schematic of the ididt tilt column.
