avatar_73TopBanana
gas filters
Started by 73TopBanana, June 18, 2021, 10:33:07 AM
73TopBanana
Hi all, would appreciate suggestions on non-glass, non-plastic and or the "large" metal stock filter.
On the small block engines, the large stock filters get in the way of checking the engine oil.
benguin
I'm running a stock Mopar metal filter, and haven't noted any issues.  Possible need to slightly adjust the fuel lines??
Can you share a picture?
Skdmark
On my 71 with a 318, the fuel filter was between the body fuel line and the fuel pump.
Mounted down low and out of the way.
-Harlan Ellison
:stayinlane:
73TopBanana
Thanks, will take a pic and post it. Have a good weekend.
73TopBanana
Cratos
mount it on the fender :)
