K frame ID
Started by 61K T/A, May 22, 2017, 08:36:46 AM
61K T/A
I have a "12" stamped on the button on my K. Is this enough info to ID it? Just curious what it will fit. Thanks,
2962012   318/340/383  E body
#2962012 Crossmember (K-Frame) 318, 340 & 383 Engines    :bigthumb:
1 Wild RT is good!   :clapping:
Cudamike
Is a 440 K Frame different than the 318, 340 and 383? I have read it was the same for a v8 except hemi.
6bblgt
1970-'71 e-body 440HP (& 440 SIX PACK) use a K-Frame with a skid plate on it
71GranCoupe
Quote from: 6bblgt on May 22, 2017, 11:01:05 AM
What is the number for the k-frame with the skid plate?
1970 E-Bodies with Skids can have these numbers.  But some of them will not have the skid plate if they were used with 318, 340 or 383's.  Just depends on what it was used for.  14 (Hemi), 76 (Hemi), 74 (440), 77 (440).  There's also a date code stamped in the front of the K-Frame.  It's small and a four digit number.  For example, 3119 would be 311th day of 1969.
Quote from: 71GranCoupe on May 22, 2017, 11:10:54 AM
71GranCoupe
Quote from: Cuda Cody on May 22, 2017, 11:18:04 AM
Thanks Cody!! I have a 1970 project car with a 318 engine code, but has a k frame with the skid plate. I will have to check it out.  :thankyou:
61K T/A
You might as well add another number 12 (Hemi) to the list Cody.
61K T/A
I thought 12 was for 318, 340 and 383's?  Not Hemi's, right?
Quote from: 61K T/A on May 22, 2017, 12:46:46 PM
