Rear end
Started by icemn1970, October 07, 2019, 02:40:39 PM
icemn1970
I am currently drag racing my 1970 small block Challenger. It has a braced 8 3/4 rear with a spool. I am contemplating going with a Ford 9 inch or staying with what I have. Looking for some input. I am running low 10's in the quarter with 1.40 60 ft times.
Brand new  B-Body width Strange Dana 60 from DrDiff....  :alan2cents:  Offset shackle kit too
https://www.doctordiff.com/strange-60.html
the Furd 9 will slow you down , they have horrible rolling resistance / drag .
If what you have is working why change ???
Dana would be the only option in my experience .
We used to have a way of determining what diff a race car had without looking under the car , if 1 guy was pushing the car easily it was 8 3/4 or Dana , IF 5 guys were pushing a car & working up a sweat going downhill you knew it had a Furd in it , True Story !!
I am a Dana 60 fan as well. I would run the 8 3/4 until it breaks and at that point install a Dana 60. The Dana 60 doesn't require all the aftermarket parts a 9 inch does, the downside is changing the gears takes time with a Dana 60. With the cost of aftermarket 9 inches though I can't imagine how you could have more than one center section $$$$
BTW Welcome to the site  :wave:
Pictures would be cool if you have time  :bigthumb:
@icemn1970   low 10's is super impressive!!!
Quote from: Chryco Psycho on October 07, 2019, 07:36:17 PM
:iagree:
:needphotos:
Someone had to do it....
 :welcome: From central New York!  :stayinlane:
QuoteI would run the 8 3/4 until it breaks and at that point install a Dana 60.
If you are considering a rear end change, I would do it "off season" and not wait until you have a failure.  Once that 8 3/4 breaks, it will take out other parts...probably in the trans.  I personally wouldn't be happy having to pull apart the trans to make sure there wasn't a sprag failure after the rear end exploded. :alan2cents:  With the times you're running, the 8 3/4 is on borrowed time.
mopar thunder
I ran a Stalwart Ford 9 inch rear, aluminum center section, Moser 35 spline axles with Strange 430 gears and ran upper 9's and never had an issue.
icemn1970
icemn1970
icemn1970
Just took vacation up your way earlier this week!
