avatar_Cudajason
RH transmission - The Result
Quote from: Cudajason on September 28, 2021, 02:58:30 PM
Quote from: blown motor on September 28, 2021, 02:56:09 PM
Forget the gas savings. The real reward to all this is putting on some miles to hang out with guys like Brad and I!  :haha:
there is some truth to that Murray.
Smiles per gallon!
Yup... Fuel mileage wasn't really part of my reason for wanting O/D... I look at it as an added bonus.... I like traveling at or above the speed limit without listening to the engine spinning 3K plus... I've driven a 440 with 4:10 gears over 1000 miles doing 60 MPH so obviously I know the cars will do it, but I'd rather not listen to it....
@Cudajason
I chased the same over charging issue for a long time. Partial failure was thru harness. There is a wire that feeds your vreg the voltages being put out. IIRC it is blue.
It should be reading very close to the charging volts. Mine ended up reading over 2 volts lower than actual charge. It was not consistent and caused spikes as well.
Ended up separating that wire from harness (figuratively) and running a new one that is fed with a switched reelay.
Before final diagnosis, the spikes ended up ruining my alt. It then pegged to 16 volts. No longer taking a signal from vreg.
Replaced alt and added the relay wiring and it has been rock solid since.
Quote from: YellowThumper on September 28, 2021, 07:42:29 PM
@Cudajason
Ah....the joys of 50 year old wiring and connections...... :steamingmad:
@Cudajason
@YellowThumper , thanks...do you have details on the relay wiring, I would like to see that.  I think that is part of my issue.
we can move this discussion over to this thread....
https://forum.e-bodies.org/electrical-and-audio/11/-over-charging-issues-battery-issue-update/22970/msg274921#msg274921
