normal_post in Ruined my Carter AVS in Engine, Transmission & Rear End Author Topic: Ruined my Carter AVS  (Read 474 times)
Offline tparker
  • Trade Count: (0)
  • Big Block
  • Credits: 3070
    • Share Post
xx in Ruined my Carter AVS in Engine, Transmission & Rear End
« on: January 30, 2019, 01:38:06 PM »
Ack. just ruined my Carter carb. I picked up an AVS long time back and was trying to rebuild it. It's quite worn and corroded. The Air mixture screw broke off when trying to take it out. I didn't realize HOW fragile the screw was. I didn't think I out that much torque on it. THen the little screws on the butterfly valves broke off. Those were little brass screws. Argh. Tried drilling them how and tap. Kinda got the butterfly screws out. But a tap broke off in the carb body when trying to take the air mixutre screw out. WTF. LOL.
Luckily I got an old Thermoquad I'll use temporarily until I can get something more correct.
Be careful when restoring.
Tom
Linkback: https://forum.e-bodies.org/engine-transmission-and-rear-end/4/ruined-my-carter-avs/10035/
Offline Cuda Cody
  • Administrator
  • Trade Count: (6)
  • E-Body Wizard
  • index in Ruined my Carter AVS in Engine, Transmission & Rear End
  • Credits: 19390
    • Share Post
Re: Ruined my Carter AVS
« Reply #1 on: January 30, 2019, 02:05:01 PM »
Dang, that sucks.  :(
Offline Bpret
  • Trade Count: (0)
  • Small Block
  • Credits: 1250
    • Share Post
« Reply #2 on: January 30, 2019, 04:33:09 PM »
You sound like a do it yourself kind of guy. But I sent a carb to Scott Smith Harms carbs with broken off screws. It came back like new. Not saying he can fix yours but itís worth a try. What carb are you looking for?
Offline 71-440
  • Trade Count: (0)
  • Six Pack
  • Credits: 8880
    • Share Post
« Reply #3 on: January 30, 2019, 05:27:27 PM »
Don't sweat it. Crap like that happens to me all the time.  :Thud:
 You'll get it straightened out.
Joe
AF1QipM9IgDaJpLCaEYdMySFg0V_u2Z8_G76BNub7EV1 in Ruined my Carter AVS in Engine, Transmission & Rear End
Offline tparker
  • Trade Count: (0)
  • Big Block
  • Credits: 3070
    • Share Post
« Reply #4 on: January 30, 2019, 07:39:25 PM »
Ha, yes. Not having a ton of cash equals 'do it yourself'. Did way more than I thought I could. Made plenty of mistakes, but the project is coming along. This is the first semi expensive mistake. The carb only cost $100, but to replace it will be several hundred. I got a thermoquad, but need a Carter AVS for a 70 challenger.
Offline jimynick
  • Trade Count: (0)
  • Six Pack
  • Credits: 17670
  • If you've got to ask, you don't understand!
    • Share Post
« Reply #5 on: January 30, 2019, 08:32:23 PM »
I'd think there was an AVS out there that needed rebuilding for $100. Make a thread asking and who knows?  :cheers:
Offline Rich G.
  • Trade Count: (2)
  • Six Pack
  • Credits: 10410
    • Share Post
« Reply #6 on: January 31, 2019, 05:04:06 AM »
Breaking a tap is the worst. Iíve used a dremmel with a carbide bit to get a broken tap out. Donít know what size youíre dealing with but they do make pretty small  heli coils if the threads are messed up.
Offline tparker
  • Trade Count: (0)
  • Big Block
  • Credits: 3070
    • Share Post
« Reply #7 on: August 28, 2020, 10:38:52 AM »
My Carb saga. LOL. I got the engine in the shop finally and that is forcing me to finish the carbs.
As an update.  I wasn't able to get the screws out of the other one. Maybe I'll work on it a bit later with much better bits. But I've found out a few things that might be helpful. I bought another AVS from Tony's for a bit over $100. I got one that matches my year car. The TQ would work, but it is a late model and there are a few issues. I might keep an eye out for an earlier one. The AVS is only 600 CFMs which is ok for the short term, but I think the stroked 340 will want more fuel, so I might end up going with an Edlebrock 750 later down the road.
Those brass screws are temperamental. Please be VERY gentle with them if you attempt to do the work yourself for the first time. It turns out the back side of the screws are "mushroomed" out. They put a nick down the center of the screw and flare it out a bit. I suppose this was to ensure the screws wouldn't work loose and find their way into your combustion chamber. Very thoughtful. :) but if you're not aware, this causes the very fragile screws to get stuck and break off when you remove them. For the new carb, I worked them out very carefully. I went a quarter turn at a time and then screwed it back in and out a few times. Then worked it out another quarter turn. You could probably also use a dremel to grind out the flare, use penetrating oil to keep things lubed. Introduce some shock to break things free, and heat to expand the metals. I didn't do any of the later.
I found a few sources for the screws, though they seem to be generic and not AVS specific from Mikes Carbs parts and a few other places. Just search AVS brass screws and a few options come up.
Then next thing I found out is that the AVS is not as popular and parts are a little harder to find. Some ABS parts will work. The rods and jets are interchangeable, with a minor change to the cover.
Just adding some comments in case it helps someone later.
clip
Carter AVS and AFB - WIW
Started by Floyd
Last post June 08, 2017, 11:58:28 AM
by Michael_B767_ATP
clip
Carter 9636
Started by dart4forte
Last post August 31, 2019, 02:03:57 PM
by dart4forte
clip
WIW - 4933S Carter AVS
Started by Rutro
Last post March 09, 2019, 08:52:54 PM
by Rutro
xx
Odd carter afb part
Started by cuda hunter
Last post March 18, 2020, 10:40:47 PM
by cuda hunter
xx
Carter carb
Started by bc3j
Last post June 17, 2018, 01:32:45 PM
by 6bblgt
