starter interfering with exhaust
Started by GoMangoBoys, March 05, 2023, 06:13:19 PM
GoMangoBoys
So I hit a snag this evening.  The starter interferes with the exhaust.  We are running the larger B body bell housing with the 143 tooth flywheel.  We also have the 2 1/2" TTI exhaust with the HP cast iron manifolds.  The starter is just barely hitting the pipe.  I am tempted to just dent the pipe a bit.  Any other suggestions?  Is there an alternative starter available that is smaller?  I am not sure how much clearance I really need between the starter and the exhaust pipe?
A mini starter should help. If I remember correctly, the 90's Dakota V8s used one and there are all kinds of aftermarket suppliers too. Check Summit, get the part# and then check Rock Auto and see how you do.  :cheers:
Daveh
I have a mini starter and TTI headers on my 340 and I still had to dimple the header just a bit.
BIGSHCLUNK
Mini starter IMO is the way to go. Just from the heat transfer aspect if nothing else
71GranCoupe
Quote from: BIGSHCLUNK on March 07, 2023, 07:44:32 AM
I really like the idea of the mini starter. Does anyone know of a good part number for one. I would like to use one on a small block and a big block. are they interchangeable?  :notsure: thanks in advance for any help or suggestions.   :thankyou:
Daveh
Blowout
A 1998 Dakota 318 starter, new by Remy is $113 on Rock Auto. Just FYI   :cheers:
You need 1/2 clearance for sure & maybe a heat shield , definately not good to be touching , the larger belhousing is moving the starter out so it touches the pipe , the challengers has 130 tooth which is why the pipe is not bent to clear properly .
