avatar_Cudajason
To PULL or not to PULL - that is the question!
Started by Cudajason, September 24, 2018, 10:10:55 AM
So I am planning to change the cam (and valve springs)  in my 360 this winter...I am pretty sure I can change it in the car, but does it make sense to pull the engine and replace all the gaskets etc.
I figure I have half the engine apart...do I go a little further and make sure everything is sealed up really well.
I do have an oil leak somewhere...so I guess that is the answer to my own question...
:notsure: :notsure: :notsure: :notsure:
When was the last time the engine was "refreshed"?  If it has been a while, or you are not sure, then I say pull it and git er dun!
Spend a little more now and drop a Hellcrate motor in there :banana:
If you're pulling the heads off to do the valve springs you might as well pull the engine and do the pan and rear seal. Then you can paint everything and make it look pretty again!
Quote from: 303 Mopar on September 24, 2018, 10:29:49 AM
Engine was apart more than 18 years ago.  in that time it was mostly off the road, so probably less than 5000 miles on the engine.
I have no intentions of putting new bearings in it or new pistons rings...just new gaskets / seals.
I guess my fear is that I pull it apart and find something wrong with it that will necessitate a full on rebuild with machining...I just do want to get into that!!!
I'd say neither!
I would drop it out the bottom via k-member!!!
kathyscuda
we don't all have alans hellcrate money.
pull it out the top.
pull the heads and regasket it.
done.
You're only taking off the intake and accessories off the front. Leave the engine in the car. Even if you were pulling the heads I would leave the engine in the car. You can do the cam change in an afternoon. But not if you are pulling the engine out of the car. However, if this is your 'Canadian winter' project and will have 5 months to mess around with it, by all means, put it on the stand.  :drinkingbud:
Narrow down your oil leak. I would leave it in the car. Actually most oil leaks can be fixed in the car as well.
I've done cam swaps in a day fairly easily before including spring swaps, so there is no need to make this bigger than it has to be.
Cudakiller70
I agree with the other lads about doing it in the car- unless, if the leak is the rear main, then I'd pull it out but not necessarily totally apart. Having said all that and in the scenario where it comes out to pull the pan and seal, then you'd be well advised to pull a couple of the rod caps and a main or two to look at the bearings; because if they're getting tired, 5000 miles or no, then you're in the right place at the right time to stick a new set of bearings in before you button it back up. You can borrow my engine hoist and stand if you go there.  :wave:
Quote from: Cudakiller70 on September 24, 2018, 08:03:17 PM
Any idea on condition of your freeze plugs?
Between this comment & it seems to me you've been fighting an overheat condition... I'd pull it, knock the freeze plugs out, flush the block like you never could in the car, seal it up & give it a coat of Krylon....
You either just do a cam swap or go ahead and rebuild the engine if it's at all questionable, in my opinion.
I just did a cam swap with the engine in my warlock, I'll pull it sometime down the road.
