What power train should I go for?
Started by Gizmo327, July 23, 2019, 08:32:06 PM
Gizmo327
I am currently looking at getting a Cuda or challenger and am wonder what engine transmission combo I should be looking at getting without getting crazy expensive
70 Challenger Lover
I guess it would depend on what you want to do. If cruising only, I'd get a stock 360 or 383 with an auto and build it for low end cruising power. Lots of them out there. If fuel economy is important, you can build a peppy little 318 that doesn't suck down the gas but still has a bit of power for fun. Of course if you want to destroy tires in a single night, none of these options will do.
Need a lot more info ,
You could look at a Gen 3 drop in , 360s are basically free to start with but require $$ to build up
What do you want to do with the car ultimately ?
Gizmo327
mostly causing and maybe the odd weekend road trip. Power to pass on the highway if need.
I do like the power in my Hemi Ram truck lol
70 Challenger Lover
Occasionally, I see someone selling a 360 or 318 that's been rebuilt but abandoned in favor of something different for their project. I think I'd keep an eye out for something like that or a decent used but running motor you can just drop in. Couple weeks ago I saw a 360 for $1800 freshly rebuilt.  It sounds like that would fit your needs and get you on the road. You can always swap it out later.
Often you can find a Gen 3 Hemi from a crashed vehicle for a reasonable price , it still takes some $$ to make it work as you need a computer . mounts , headers etc but it gives you godd drivability & power  :bigthumb:
What are your skills at tuning a carb, fixing basics on an engine and trans, maintenance? If reasonable a 318 or a 360 would be cheapest with a 727 auto.  If not so much or you want less maintenance the a 5.7 Hemi is pretty cheap and easy to find.
"What power train should I go for?"
Steam? Always liked Steam Locomotives....   :pokeeye: :pokeeye: :haha: :haha:
Powertrain on the other hand....  You have allot of questions to answer before we can really give a good suggestion...
70Barracuda
E's take a lot of money.  How much you got?
mopar jack
Well if  i could jump in a time machine I would go back to the 90's and buy an old chrysler with a 440 and auto that would not pass smog for  $500 and pull the motor, trans, alt, power steering pump and drop it in and run the doors off it or wait for a pick and pull  1/2 off sale and pull one from a wrecking yard for $100.
Gizmo327
still learning but from what am seeing that not all 440 were 6 packs and I assume 6 packs would be more preferable?
70 Challenger Lover
Quote from: Gizmo327 on July 24, 2019, 06:15:39 PM
It comes down to what you want to do. If only cruising, a 440 is not necessary. A 440 six pack is definitely not necessary. More desirable yes but a 426 hemi is even more desirable than the six pack so if desirability is the driving factor and money is not, than I'd opt for the hemi.
A Six pack looks better but any 440 is cool. A 440 swap is the easiest way to perk up an E-body. As said though the old days of find a good running New Yorker for $500 and swapping it into an E-body after doing a timing chain swap are long gone.
440 requires a trans swap , small blocks & 3rd gen Hemis do not
Gizmo327
What does a 440 with purple can mean?
