Exhaust for maximum ground clearance
Started by Scooter, April 18, 2020, 11:49:10 AM
Scooter
^^^ Yup.. yours are much higher. Do you have a shot from the back?
Quote from: Scooter on April 18, 2020, 08:28:46 PM
Can't find anything.... will try & get a shot in the near future
Scooter
Looking at your last picture post. Looks like the engine/trans combo is leaning down to the right. What type of motor mounts are you running ? Looks to be the problem as well as you stated that the torsion bars are adjusted down. That was the point about ride height.
Quote from: Scooter on April 18, 2020, 08:39:27 PM
Thinking of replicating this setup Topcat has, with an X pipe.
Cant easily go wrong with that type of ground clearance.
Go for it! You'll love it.
Best way to describe  it's sound...
Floats like a Butterfly, Stings like a Bee.
Quote from: Topcat on April 18, 2020, 09:08:45 PM
The hemi might have something to do with it...
Scooter
Quote from: MoparLeo on April 18, 2020, 08:51:23 PM
Believe it's just an optical illusion because the passenger side header tube hangs soo low. But I see what you are talking about, that looks like one mean lean at a glance. Motor mounts are poly-locks.
I see what you mean but I was looking at the angle of what looks like the trans pan. Actually having the car on a rack gives you a very good horizontal perspective of what is parallel. Have you put a level across the valve covers or carb opening ?
Took a few underside pictures of my car this morning, small block, TTI full length headers, TTI 2.5" exhaust with TTI 6 degrees header adapters. Hope this help.
70Barracuda
Question,  How close to the floor or anything should the exhaust be?  Taking my car today to a guy to talk about all new.
How close to the floor where ? Depends on whether the floor is undercoated with the tar type stuff or with a bed liner type of material. Or just straight paint Type of insulation or sound deadener used under the carpet. Lots of variables.They generate a lot of heat so act accordingly.  :thinking:
Scooter
Quote from: 7212Mopar on April 19, 2020, 11:19:26 AM
Extremely helpful, thank so much for taking the time to do so!  :bigthumb: Going to get out and take some more measurements today.
A skid plate added to the K member may offer some relief on exhaust hitting.
If you modified it making sit even lower; might be an idea to consider as well.
https://www.doctordiff.com/reproduction-skid-plate.html
Scooter
Quote from: Topcat on April 19, 2020, 05:15:16 PM
Not planning on going any lower... lol.
Just noticed you are in Fremont, was in your neck of the woods today. Saw a nice orange 72 Challenger cruising up Stevenson.  :)
shawge
 :alan2cents: double check the engine/transmission angle (IIRC it should be 1-3 deg down from horizontal).  This can affect the header to ground clearance.
Colored wiring diagrams
Wheel spreadsheet
