avatar_Chryco Psycho
Guide for initial engine fire up
Started by Chryco Psycho, January 10, 2017, 08:19:07 PM
At least around here (Buffalo), I'm seeing more and more gas stations offer a pump selection for "ethanol free'" gas @ 91 octane, so we can stay away from the ethanol.
73_Cuda_4_Me
Chryco, can you set the idle mixture screws with throttle set to get an engine speed at 1800-2000 RPM?
BS23H3B
They will adjust the total amount of fuel going into the engine & may help keep it cooler at 1800 rpm but when you idle down the settings will usually be different , so if you have to lean them the jetting is too small , if you have to richen them the jetting is too large
MOPAR MITCH
T/Anks Chryco!!!!  I hope to have a new S/B engine in 2018.
