avatar_Cuda Cody
"Engine" Build Sheet codes (1970 E-Bodies)
Started by Cuda Cody, March 09, 2017, 07:54:43 AM
If you have a 1970 E-Body Build Sheet could you please check to see if you have a number not shown here?  If you have one not shown on this list could you tell me:
~The Engine Code Number on line 4 (left side of sheet) under "ENGINE"
~The Transmission code (2 boxes over same line) i.e. 13,21,31,32 ect
~The Heater Box Code (H11 or H51)
Thanks for all the help.  @6bblgt  and @cataclysm80  might be able to fill in some of the ones I'm missing :fingerscrossed:
021 = 225 1 Barrel w/ A904 Auto Trans & Heater
047 = 318 2 Barrel w/ 3 Speed Manual Trans & Heater
059 = 318 2 Barrel w/ A904 Auto Trans & Heater
072 = 383 2 Barrel w/ A727 Auto Trans & Heater
073 = 383 2 Barrel w/ A727 Auto Trans & AC
084 = 383 4 Barrel w/ A833 Manual Trans & AC
085 = 383 4 Barrel w/ A727 Auto Trans & Heater
086 = 383 4 Barrel w/ A727 Auto Trans & AC
087 = 383 4 Barrel w/ A833 Manual Trans & Heater
088 = 383 4 Barrel w/ A727 Auto Trans & Heater
089 = 383 4 Barrel w/ A727 Auto Trans & AC
110 = 426 Hemi w/ A833 Manual Trans & Heater
111 = 426 Hemi w/ A727 Auto Trans & Heater
112 = 426 Hemi w/A833  Manual Trans & Heater
113 = 426 Hemi w/ A727 Auto Trans & Heater
114 = 440 4 Barrel w/ A833 Maunal Trans & Heater
115 = 440 4 Barrel w/ A727 Auto Trans & Heater
116 = 440 4 Barrel w/ A727 Auto Trans & AC
122 = 440 6 Pack w/ A833 Manual Trans & Heater
123 = 440 6 Pack w/ A727 Auto Trans & Heater
134 = 340 4 Barrel w/ A727 Auto Trans & AC
138 = 340 4 Barrel w/ A833 Manual Trans & Heater
146 = 340 6 Pack w/ A727 Auto Trans & Heater
148 = 340 6 Pack w/ A833 Manual Trans & Heater
150 = 440 6 Pack w/ A833 Manual Trans & Heater
193 = 198 1 Barrel w/ 3 Speed Manual Trans & Heater
112 & 113 might be B-Body codes?
Some of the Engine codes I'm still missing:
198 Auto trans w/ Heater
225 Manual trans w/ Heater
318 Manual trans w/ AC
318 Auto trans w/ AC
340 Auto trans w/ Heater
340 Manual trans w/ AC
383+2 Manual w/ Heater
383+2 Manual w/ AC
440+4 Manual trans w/ AC
6bblgt
048 = 318 Manual trans w/ AC
060 = 318 Auto trans w/ AC
133 = 340 Auto trans w/ Heater
GONE for '70 = 383+2 Manual w/ Heater
GONE for '70 = 383+2 Manual w/ AC
NEVER = 440+4 Manual trans w/ AC
still missing:
6bblgt
the 318, 340 & 383 manual transmission spec. engines are going to be for both 3-spd (PP230) & 4-spd (PP833)
6bblgt
084 = 383HP 4 Barrel w/ A833 Manual Trans & AC (orange Holley 335hp)
085 = 383 4 Barrel w/ A727 Auto Trans & Heater (blue Carter 330hp)
086 = 383 4 Barrel w/ A727 Auto Trans & AC (blue Carter 330hp)
087 = 383HP 4 Barrel w/ A833 Manual Trans & Heater (orange Holley 335hp)
088 = 383HP 4 Barrel w/ A727 Auto Trans & Heater (orange Holley 335hp)
089 = 383HP 4 Barrel w/ A727 Auto Trans & AC (orange Holley 335hp)
6bblgt
"IF" the highlighted numbers exist  :dunno: you need to differentiate WHY? there are 2 codes for the same apparent engine assembly number
Not sure why they changed codes, but it appears to be date related.  Early vs late.   :thinking:  What did they change later in the year?  :clueless:
Quote from: 6bblgt on March 09, 2017, 12:34:26 PM
A.Gramz
Clean air act 1970. Would It have anything to do with it?  Not sure when that came into effect it was a little b4 my time.
Nice job 6bblgt!!!!  Looks like there's only a couple left.  I'll ask on the facebook group to see if we can find the last few.  Here's what we know we need.  There might be a few others too so check you sheet and let us know if you have a number that is not listed below:
still missing:
021 = 225 1 Barrel w/ Auto Trans & Heater
047 = 318 2 Barrel w/ Manual Trans & Heater
048 = 318 2 Barrel w/ Manual Trans & AC
059 = 318 2 Barrel w/ Auto Trans & Heater
060 = 318 2 Barrel w/ Auto Trans & AC
072 = 383 2 Barrel w/ Auto Trans & Heater
073 = 383 2 Barrel w/ Auto Trans & AC
084 = 383 4 Barrel w/ Manual Trans & AC (Orange Painted Engine & Holley Carb 335 HP)
085 = 383 4 Barrel w/ Auto Trans & Heater (Blue Painted Engine & Carter Carb 330 HP)
086 = 383 4 Barrel w/ Auto Trans & AC (Blue Painted Engine & Carter Carb 330 HP)
087 = 383 4 Barrel w/ Manual Trans & Heater (Orange Painted Engine & Holley Carb 335 HP)
088 = 383 4 Barrel w/ Auto Trans & Heater (Orange Painted Engine & Holley Carb 335 HP)
089 = 383 4 Barrel w/ Auto Trans & AC (Orange Painted Engine & Holley Carb 335 HP)
110 = 426 Hemi w/ Manual Trans & Heater
111 = 426 Hemi w/ Auto Trans & Heater
112 = 426 Hemi w/ Manual Trans & Heater
113 = 426 Hemi w/ Auto Trans & Heater
114 = 440 4 Barrel w/ Maunal Trans & Heater
115 = 440 4 Barrel w/ Auto Trans & Heater
116 = 440 4 Barrel w/ Auto Trans & AC
122 = 440 6 Pack w/ Manual Trans & Heater
123 = 440 6 Pack w/ Auto Trans & Heater
133 = 340 4 Barrel w/ Auto Trans & Heater
134 = 340 4 Barrel w/ Auto Trans & AC
138 = 340 4 Barrel w/ Manual Trans & Heater
146 = 340 6 Pack w/ Auto Trans & Heater
148 = 340 6 Pack w/ Manual Trans & Heater
150 = 440 6 Pack w/ Manual Trans & Heater
193 = 198 1 Barrel w/ Manual Trans & Heater
Culvers
019 = 225 1 Barrel w/ Manual Trans & Heater
Culvers
#9
Quote from: Cuda Cody on March 09, 2017, 07:54:43 AM112 & 113 might be B-Body codes?
I would say YES. On E-bodies I only found 110 + 111. 112 + 113 only on B-body
I found one sheet with 113 on a V-code Cuda auto.  :notsure:
150 also only on B-body
6bblgt
Quote from: Culvers on March 10, 2017, 02:07:04 AM
can you post a picture?
Rev-It-Up
There wasn't much left of the sheet from my 70 challenger, but I was curious what it said after reading this post.  In the engine section it says 63...I didn't see that in your list.   :dunno:
Rev-It-Up
Thank you Rev for the help.  That's cool you still have a photo of your old build sheet!   :banana:  There's a couple spots on a sheet that tell you about the engine.  Hope this helps.   :slapme5:
Rev-It-Up
Oops...sorry...i was looking at the wrong box at that 63.  Thanks!  :thankyou:
Rev-It-Up
