Brake Booster Identification Help
Started by 70_440-6Cuda, January 13, 2023, 04:51:15 PM
0 Members and 11 Guests are viewing this topic.
fc7cuda
There are some very affordable options if ya don't want to pay the $1K+ for a 171 and another few hundred to have it overhauled.   :alan2cents:
EV2RTSE
@fc7cuda that looks good! What is that a Raybestos? Or a Centric maybe?
headejm
Quote from: fc7cuda on January 18, 2023, 07:42:43 AM
@fc7cuda Please share the options for the 171. My car is (mostly) all original but I'm never interested in overpriced OEM-type parts. Master cylinder is one part I would never pay $1k+ for.
70_440-6Cuda
Would also love to know the details, thanks!
Jocigar
I'm all ears also, did a search of ebay, facebook and craigs list, nothing for booster much less 171.
I have a long way from needing the set-up.    When its a bolt on part like this, I would be ok with affordable alternative and casually shopping for better deal on original parts to swap out later.
@anlauto  more questions please;
so the wrong booster that I have in pics would be correct for my 71 vert someday down the road?  and would it still need to mate to 171 for disk set-up in 1971?
lastly, I have 73 parts car with disk, do any of those booster/master parts apply to 1971?  maybe I can use 71 midland booster and 73 MC together is what im thinking for the 71', or the entire 73 unit.   I did notice the proportioning valve looks different in 73.     Thank you !
The "171" master is correct for 1970 only with a possible early build 1971's as well. It's a "187" I believe for 1971 which has a totally different appearance then the "171"
EV2RTSE
Yup the 187 master was used 71-74 and the Midland Ross booster 71- at least 73. Proportioning valve changed to the newer style in 73.
EV2RTSE
The Centric 130.63055 and Raybestos MC36283 are two possible options that have been suggested as something that resembles an original 171 master, as a cheaper alternative anyway. Especially once painted black.
Centric-
https://www.summitracing.com/parts/ceb-130-63055
Raybestos-
https://www.summitracing.com/parts/agb-mc36283
440ehigh
That's my question / problem. I found a 187 a few years ago and had it sleeved. I was just going off model year casting numbers not date of build. Or realize the booster I verified as correct was a 70 only booster but the car being a 8-70 build would understand why it had the 70 Bendix booster. Just seeing if it would make sense that it has a 71 correct master with a 70 booster.  Didn't know if they could pair together or not. Because with the rising cost of everything i bet to get a master cylinder re sleeved is getting pricey on top of  the core charges of a 171.
EV2RTSE
I seem to recall reading some threads on the other boards that said the Midland Ross booster didn't start showing up until as late as Jan-Feb of 71. So it would seem that yes you could have a 187 master paired with a Bendix booster.
fc7cuda
Quote from: headejm on January 18, 2023, 12:23:55 PM
@EV2RTSE
@headejm
The one in my pic is the Centric #13063055
https://www.rockauto.com/en/moreinfo.php?pk=1617730&cc=1495993&pt=1836&jsn=927
It is acceptable in appearance for me, a trained eye can reconize it's not a 171 due to the slight difference in width.
Quote from: fc7cuda on January 19, 2023, 05:43:55 AM
@EV2RTSE
@headejm
Maybe if it wasn't for the "casted ports" on both sides, it would be a decent copy of the "171"  :alan2cents:
Jocigar
Hi all, If I found a correct booster but it needed rebuilding and also the master cylinder shaft was broken... as I am being told, is it scrap or salvageable?   If it can be saved, how much would you pay for it and where would you send it for repairs.   or should i just walk away and wait for better unit to come along.   Thank you!
70_440-6Cuda
Any suggestions for a good / close reproduction of the Bendix booster?
70_440-6Cuda
Is the the correct booster set up for a '70?  Want to verify before I buy... thanks!!
