avatar_Daveh
Brake Cable To Firewall Grommet
Started by Daveh, August 15, 2017, 08:28:40 AM
Mrbill426
Ok, so maybe if they are not part of a molded-in washer the re-op could be stretched over the end of the assembled cable.
Quote from: Burdar on September 16, 2017, 08:51:26 PM
On my original grommet, the rubber was molded around the metal prongs.  On the reproduction, the prongs just stick out of the rubber.
HEMICUDA
If you're looking for an exact reproduction, I made them for Fine Lines.  However, I think Bob sold is remaining inventory to Jim at Detroit Muscle Technologies.  I even had the "H" & "B" molded into them.  The easiest way to install them on new cables is boil a cup of water and throw the grommet in, grease the end of the cable and you'll get it on.  All originals have a metal ring with the tabs stamped into it.  Two of the three tabs are bent to hold the grommet in and the other was used for alignment.
