HEMI power steering hose
Started by Cuda_mark, August 08, 2018, 06:42:24 AM
Cuda_mark
So I bought 2 different power steering hoses from Rock Auto that were listed as correct for 1970 HEMI e body but both were different and incorrect. Does anyone know what part number/manufacturer hose has the correct length and bends? I don't need it to look perfect, just need it to work.
I am using the correct federal pump with the discharge in the front.
Your best bet...
http://www.rogergibsonautorestoration.com/Parts/Parts-Supply-Home/
P/N: HOSE
70-71 HEMI, e-body and b-body power steering hose. Correct fit and size, but not
authentic hose or end fittings......................................................................
$135.00 Each
Do not buy the reproduction return hose.
It is not made correct and cannot handle power steering fluid.
It'll swell up and leak. Built for trailer queens.
Cuda_mark
Quote from: Topcat on August 08, 2018, 07:00:52 AM
Your best bet...
P/N: HOSE
$135.00 Each
Thanks for the advice Topcat. I think I checked with roger and that hose was out of stock and not manufactured anymore. Thats why I started search Rock. I'll check again with him.
Yeah I could use one myself.
Let me know what you  find out.
If you have a bad original hose, you could probably have a local hydraulics shop crimp on a new hose...just reuse the original hard lines.
Cuda_mark
Quote from: Burdar on August 08, 2018, 09:16:36 AM
I don't even have an original hose that fits so that's not an option.
