How can I slightly raise the rear end of my 70 cuda?
Started by Waco, July 21, 2022, 02:42:48 PM
Waco
I'd like to raise the back of my cuda a little to give it a little more aggressive look vs the stock setup/suspension. What's a good, permanent way to raise the rear end properly?
BigSig 6 Barrel
#2
I just took in a very low mileage set of OEM Mopar superstock springs in trade, id sell for $175 + shipping
They would raise the rear of your car by around 2"
Pictures available:
Contact me if interested
Dave
~ A Wise Man Knows He Isn't
Waco
Quote from: JS29 on July 21, 2022, 02:44:50 PM
New springs, Or re-arching your old one's.  :alan2cents:
Who makes the best springs that will raise that rear some?
I had my originals re-arched to what I thought would be good. It wasn't as much as I wanted so I took them back and the spring shop added a little more, no extra charge. Maybe I got lucky. It was a little extra hassle but now I love it.
Waco
Waco
Quote from: BigSig 6 Barrel on July 21, 2022, 03:00:01 PM
Pictures available:
Dave
Message sent
GrandpaKevin
You can replace the front spring hangers with a 2 hole setup.
Cheap and easy to install.
Bottom hole is stock height.
Top hole raises the rear about 1"
Racer57
Quote from: GrandpaKevin on July 23, 2022, 07:07:26 PM
I might be wrong, but doesn't the top hole lower the car since its farther up ?
MoparCarGuy
I second going to adjustable front hangers. Latest front spring hangers are 2-hole but you may be able to find 3- or 4-hole versions. Moving the front spring eye up lowers the car. Moving it down, raises the car.
I have had 4-hole hangers with factory Trans Am leaf springs on my Cuda since 1984.
Racer57
Who sells 4 hole hangers that will lift car ? 2 hole is either stock or lower.
Maybe I'm wrong but I thought SS springs were shorter eye to eye and needed different hangers as well? Or some other modification?  :dunno:
BigSig 6 Barrel
#14
Quote from: dodj on July 25, 2022, 04:01:27 AM
Yes, that's correct dodj ... slightly longer hangers . . . nothing more.
Those brackets come with my springs, as can be seen in the photo I had posted earlier in this thread.
