avatar_Topcat
Mopar Master Cylinder 28868: Can it work on a Shaker car?
Started by Topcat, July 06, 2019, 07:24:13 PM
This Master Cylinder I have is very close looking like that to an original 426 Hemi Master Cylinder.
What I recall  is that this one was too tall and then the hood underside frame hits when you try to shut the hood.
So my questions:
Can this be modified by shaving/machining down the deck height to be the same height as an OEM was?
The over spring clamp? Do I re drill new holes lower and use the same as before?
Who knows more on this subject or has done it before?
28868 what vehicles are these typically found on?
JH27N0B
That's an aftermarket MC from Raybestos or NAPA United.  It's copied from the B body MC for 68-69 Hemi and C body 69-70 made by Bendix with casting number 2225621.
I don't know if it will fit without interference with an E body, I believe I've seen them used for that so probably will.  I wouldn't cut it down, I'm not sure how you'd make the bale wire work.
If it doesn't fit, use the aftermarket MC for 71-74 E body with disc.  It's not as tall.
Quote from: JH27N0B on July 06, 2019, 09:41:58 PM
I currently have the snub nose type working well. Height appears to be less.
What I'm trying to do is take this one and modify it.   :thinking:
I bet it's been done before.
Quote from: RUNCHARGER on July 07, 2019, 08:32:31 AM
Easier to throw the Power Booster in the garbage.
:unbelievable:
I have the OEM Hemi Bendix Brake booster.
Not many choices, based on valve cover height I'm at.
I truly believe this can, or has been done, modified. to fit without interference.
