avatar_Husk Challenger
Power steering gear leak
Started by Husk Challenger, March 03, 2018, 05:27:24 PM
Husk Challenger
Hi guys
I have a leak on my steering gear at the input shaft.
I'd like to fix it and i am looking for the good seals on Rockauto.
I would like also to change the seals of the sector shaft to prevent a future leak
https://www.rockauto.com/en/catalog/dodge,1973,challenger,5.6l+340cid+v8,1078680,steering
I am totally lost...
I think i may order a seal kit for the steering pump, but i have to check what type i have.
Any idea?
Thank you
EDL94
I have a big leak there too. I am going to use the opportunity to upgrade to a firm feel stage 3 steering box. I don't want to mess with changing the seals, and the upgrade will make me want to drive it more.  :banana:
Husk Challenger
That was my first idea, but i have other stuff to fix first like my leaf springs....so i have to wait for the FF stage 3  :headbang:
The FF stage 3 is really good.
2 to 5 weeks lead time is likely.
Unless they're in stock and you buy out right without a core.
I shipped 2 cores using Uship.com and that helped saye a little on the total cost.
Husk Challenger
Hey @Topcat,
On their website, the price is 399$ for stage 3. Is it the price whith your own core included?
73440
AT205 completely stop my power steering pump leak.
It used to completely drain empty overnight.
After over two months , not a drop has leaked out.
There s a thread on here called " aargh oil leak " about this product.
Quote from: Husk Challenger on March 04, 2018, 12:38:05 PM
Hey @Topcat,
I think so but it's been a while so I don't know for sure.
Quote from: Topcat on March 04, 2018, 03:29:42 PM
Hey @Topcat,
$399 is using your core, otherwise they add a core charger. I would highly recommend taking this opportunity to have yours rebuilt with the FF stage III.  It makes a big difference!   :banana:
Husk Challenger
@73440
Thanks for the information. I have already heard about this kind of product but i have never gived a try.
If you have good result maybe it s time to test it. It could be a solution while saving money for a rebuild by FF
Thanks Topcat!
73440
#9
I had already bought a remanufactured pump to replace the leaking one, but found out that pulleys are not an easy source.
Then @cudabob496 wrote about this AT-205 reseal and I put the  replacement pump work on hold as it is not leaking now.
Want to do the FF stage 3 also.
Husk Challenger
@73440
I've just received the AT-205. May you tell me what quantity am i supposed to add in my steering pump?
There is nothing about this in the package
73440
@Husk Challenger , I just measured, I used three (3) oz , just under 1/2 of the bottle in mine.
Mine would totally drain out overnight , and now it has not leaked a drop since using the AT-205.
Good luck with yours.
Husk Challenger
Thanks a lot.
I hope it will work for me to...  :fingerscrossed:
ramiron
What were your results with the AT205?
The seal is readily available from a local parts store(in the US that is)  All you have to do is pull off the steering coupler, run a small screw into the seal and pull it out.  The new one will tap right into place.
