Steering column
Started by booyaballer, November 02, 2017, 06:34:01 PM
booyaballer
my 70 challenger currently has a B&M Quicksilver floor shifter (automatic).  Based on my steering column, i presume it was originally a column shift car.  i plan to go with a manual transmission 4 or 5 speed, can i simply change the cover on the steering column to eliminate the gear dial and column shifter handle thing or do i need a new column for the manual transmission?
@booyaballer  Yes, your car was a column shift at some point.  You can use that column and just change out the collars.  @TONY  makes the parts you need.
http://www.tonysparts.com/newproductsE.htm
You can also find step by step How To videos here on our site:
https://www.e-bodies.org/videos/
@TONY  can set you up with all the parts you need ... http://www.tonysparts.com/newproductsE.htm
31 seconds...Really Cody ??? :steamingmad:
 :haha:  I was just typing that I beat you to it by 31 seconds, but you beat me to the 2nd reply.  You are good my Brother!      :drinkingbud:
Quote from: anlauto on November 02, 2017, 06:39:15 PM
booyaballer
that was quick! most impressive.
