avatar_wimpy
steering coulmn install
Started by wimpy, March 23, 2020, 09:26:19 AM
 @bc3j  I like to try the least abrasive to start. if it laugh's at it, then go courser.   :alan2cents:
Well I would call & ask assuming they are there
I know there are different diameters depending on manual or power steering
They will have the experience to help you & measure your diameter before calling them
I hope it is the $70 one , the other is stupid expensive  :Thud:
wimpy
Quote from: Brads70 on March 25, 2020, 03:22:05 PM
Quote from: wimpy on March 25, 2020, 12:58:05 PM
Quote from: Brads70 on March 25, 2020, 10:36:45 AM
if all else fails....  :whiteflag:
https://www.rosevillemoparts.com/product/steering-coupler-body-63-76-with-3_4-shaft-hole/
https://www.rosevillemoparts.com/product/steering-coupler-body/
OK so witch one 3 inch or 3 1/2 inch one ?
this one is 3 inch, any idea why they list 2 different sizes.
Can you measure what you have now to see? The one in my car measures 3 1/2 if that helps? 1970 Challenger
Quote from: wimpy on March 25, 2020, 04:45:24 PM
Good question! I have no idea why there is 2 different sizes?  :notsure:
bc3j
My '70 RT 383 with power steering is 3". I thought 3.5" was for manual.
wimpy
Well she's on, thanks to a crowbar and piece of wood , the big problem I had was finding the master spline on the coupler. The coupler is 3 inch. Still don't know why 2 different lengths, I think I read somewhere the manual box has a larger diameter gear. Anyhow thanks to everyone's help and guidance with this.
Manual steering input shaft is bigger so that's why the coupler is different.
Quote from: RUNCHARGER on March 26, 2020, 01:43:07 PM
:wave: Just trying to learn.....    Ok so the spline bore/diameter if you will is bigger on a manual car.
Ok I got that but why the 2 different lengths of couplers? Mine is 3 1/2" and bc3j has a 3"
Is it a Cuda vs Challenger thing?  :notsure:
Also both the links from Roseville say for power steering but have different lengths?
Not sure on the length Brad.
 :thinking:  mine originally was a column shift and I converted it to a floor shift. Bought a used column etc.... so mine might not be " correct "  but it all works ok? I'n pretty sure my current column is not correct for a 70 but a later one as it doesn't have the lever to remove key thing.
  Just throwing that info out there if it helps solve the " why 2 different lengths " thing?
RJChallenger
Is it a truck verses car thing? I have 2 power steering and 1 manual steering couplers all 3" long
Yes: I think it may be a truck thing. They used those couplers into the 80's I believe but I don't have one here to look at.
