1970 Challenger JHN0B 4 speed Restoration Back in Swing
Started by 70 Challenger Lover, April 26, 2020, 08:27:47 PM
70 Challenger Lover
Before, I was thinking of going with undercoating when I'm done like original but as I move along, I can see why guys detail out the underside and leave it with a nice coat of fresh paint. I may just do that.
70 Challenger Lover
Still plugging away on fitting everything. Pretty happy with driver quarter. When I weld it in, I'll lift it a hair at the door jamb so it's the same height the original was at. The passenger one is good but I want to play with fit at the Dutchman panel just a little more. The tail panel fits but still needs final fitting. I'm happy with the trunk lid. That was the one unknown. A little high at the right upper corner but that's just the lip underneath popping up when I removed the clamp. Next step is to get the trunk floor in, then I'm stripping the roof skin off so I can clean and paint all hidden areas before welding everything in permanently.
70 Challenger Lover
AMD. Like everything else on this car, the original was too rusty to use.
cudamadd
70 Challenger Lover
I'm nearing the point where I want to sandblast the area that never see sunlight so I can epoxy and paint them. The area where the quarter window sits is easy with the quarters off but I also decided I want to strip off the roof and do the bracing underneath. The roof was solid enough but there were signs of corrosion hiding up in the braces. This is what I found everywhere.
70 Challenger Lover
I knew I would find issues. It was this or dipping but I had a feeling dipping would leave my roof compromised in the end so either way, I'm putting in a new one.
#25
Yup: These cars are old and that's not surprising to find unfortunately.
70 Challenger Lover
Sandblasted all structural stuff that will be hidden and covered the bare metal in epoxy primer. Gonna squirt some black paint over the epoxy today. There are a three small localized areas of rot on the passenger side I want to repair before the roof skin and quarter get welded back on. I'll have to touch up the paint again but I didn't want to leave the bare metal exposed to the open air any longer than I had to.
The supply place I normally get sand from has switched out to a newer coal media. To my surprise, it produces far less dust and cuts really nice. I used up the remaining sand on one side and then coal on the other. The coal was at least twice as fast and left an even nicer finish.
70 Challenger Lover
Now that everything is protected in there for years to come, I can turn my attention to a few smaller rot repairs.
It amazes me the depth of some of these restorations.
Everything is looking nice.
I have used Dynacorn panels on an early Falcon. They were spot on for sizing.
70 Challenger Lover
Roof came in today so I tossed it on just to see how it fit. Pretty nice overall. They damaged one area on the passenger C pillar but shouldn't be a difficult fix. For a $300 Goldenstar roof, it's far nicer than I was expecting.
