avatar_erik70rt
1970 Challenger T/A Convertible Project
Started by erik70rt, September 08, 2019, 03:13:40 PM
erik70rt
Removed the old worn out axle bearings.
erik70rt
New heads and rockers installed.
erik70rt
Made some good progress today.  Pressed the new bearings on the rear axles, then installed the backing plates and axles, then the rear brake lines and rear brakes (except the parking brake for now).  Then put on the drums and wheels.  Filled the differential with gear oil and its finally sitting on the rear suspension.  Tomorrow I'll start the front...
erik70rt
Upper control arms installed.
erik70rt
340 is almost finished
erik70rt
Sorry I haven't posted in a bit on this.   Just got the car back from the painter this past weekend.
Other than that I've just been accumulating more parts.  I'll now be getting back to it and posting more progress pics.
70 Top Banana
So, I know. This topic has come up on more than once but I am looking for the correct engine paint code for the engine in a 1970 Challenger T/A 340 6 pak. I looked and looked but could not find anything in the forum. Thanks!
erik70rt
Car is now out of the trailer and back in my garage.   Let the build continue!
erik70rt
More progress.  Installed heat riser kit.  Did some blasting and painting.
erik70rt
Flywheel, clutch, bellowing and more
erik70rt
Got the engine and trans installed today
erik70rt
cuda hunter
That looks great!  Went in quick and easy.
erik70rt
Getting back to it again.  Got all of the front suspension installed.  Still need to put in the shocks.  Hope to have the underside buttoned up in the next week or so - parking brake cables, shift rods, lock out linkage, z bar, clutch linkage, splash shields, exhaust, etc.
Yes, Alan!  I flipped the sway bar!!!   :))
