avatar_cudaragtop
69 Barracuda Fastback G3 Hemi Father Son Project
Started by cudaragtop, May 14, 2017, 10:25:45 PM
cudaragtop
October 6th 2019
Testing out the US Car Tool car lifting tool.
Lifts plenty high with the rear on ramp/blocks.
6.1 and 727 are on a US Car Tool K-Member cart.
Didn't have a transmission mount and none at the local parts store.
Amazon Prime is on it's way!
October 12th 2019
Rolled the Hemi across the patio and down the driveway and under the waiting 69 Fastback for the first test fitting.
Went well!
Several firsts for us but the QA1 K-Member bolted right up with a little bit of coaxing...
The 727 Cross member bolted right up.
Lots to test fit and mock up and then take it back out before final paint.
AC Plumbing
Heater Plumbing
CAI Fab and fit
Radiator and plumbing
Steering
All the front suspension
Having never done any of this before, I'm taking my time and thinking about what next...
Going to have to drill and cut holes for the Classic auto Air but am thinking of ways to hide as much of the plumbing as possible...
Looks right at home. Yes, it is very close to the passenger inner fender...
November 24 2019
Neon SRT4 Seats sitting in there just to get a look.
Need Seat Bases
At this point, Manual Reverse Valve Body 727 + GV OD was still the plan... That however would change...
cudaragtop
December 15 2019
I'm sure it must just be me...
Man I sure struggled trying to figure out how to put the glove box door and hinge back together in the dash...
Then when I finally got it, couldn't figure out why I struggled with it so much.
Anyway, it's done.
Fit the Dash frame in place and the Classic Auto Air Heater/AC Box is mocked up in place.
Little by little. Not a lot of progress but it all has to get done.
Ididit tilt steering column arrived today. :)
Still need the EPAS kit, then can start work on the steering.
Will have to cut the steering column down to attach the EPAS electric motor and figure out mounting the column with the motor under the dash.
May try to graft the old column bracket to the new column if it will work.
cudaragtop
December 29th 2019
Shifting Gears...
New plan. 8HP70 8-speed
They are bad ass. Will be some surgery involved but the final product will be well worth the effort.
Ordered this Ididit Tilt column and EPAS Performance Electric Power Assisted Steering Kit for the Barracuda.
Have to figure out what steering wheel, adapter and horn button we want to use.
Need to get the seats located and mounted and figure out the correct location, length, angle, etc.
Neon SRT4 Seats need to have some modified brackets made up for them.
Got a Challenger Console off of EBay
Will try to fit it with the SRT4 seats and new tunnel...
cudaragtop
March 15 2020
EPAS Electric Power Assisted Steering for the 69 Barracuda
Will be mated to an Ididit Tilt Steering Column, Momo Steering wheel and Paddle Shifters.
Had to make a plate to go on the firewall and relocate the opening to where the steering shaft will clear everything. Used the original firewall steering column plate as a template and made the new with 3mm thick plate aluminum.
Cut it out on my bench router table with a trim bit from Harbor Freight. Worked great.
A 3/4" Double "D" and 1" Double "D", a 3/4" 36 spline to 3/4" DD U-Joint, a 3/4" DD to 1" DD U-Joint, a 1" Bearing at the firewall. Collapsible Steering Shaft with Electric Power Assisted Steering.
Now to shorten and modify the Ididit Tilt Column to fit.
Really happy with the results so far.
Ididit says they will disassemble, cut the column and inner steering shaft down to my measurements for $100.00 + shipping and I can maintain the warranty.
Seems worth it to me.
A few more pictures...
The EPAS kit came with a Plate for the firewall but I think they have "Early A" for all the A-Body Barracudas and not correct for 67-69 Barracudas. So I made my own.
Cut down the stock column for all the test fitting.
Cutting my new firewall plate with my little benchtop router table.
cudaragtop
April 1 2020
Paddle Shifter for the 8HP70
From Powertrain Control Solutions
Obviously shown with a transparent steering wheel. It bolts onto the column and the wheel on top...
cudaragtop
#110
December 2020
Not for the faint of heart.
When you do a complete Nut and Bolt RestoMod it's expensive...
Partial List for my 69 Barracuda WIP 3/26/16 through today
Power Stop (AR8309XPR) Drilled and Slotted Rotor pair Raybestos Front Brake Pads Raybestos Front Brake Calipers Moog K7040 Strut Rod Bushing Kit 2 of Moog K791 Control Arm Bushing Moog K8243A Cam Bolt Kit 2 of Moog K7103 Control Arm Offset Bushing Kit ARP 240-7301 Torque Converter Bolts Moog K7074 Pitman Arm Moog K781 Ball Joint Moog K783 Ball Joint Gates 32922 PowerGrip Hose Clamp
Upgr8 5 Feet Length Stainless Steel Braided Fuel/Oil/Gas Line Hose (-8AN, Silver)
Aeroquip FCE1834 Nickel-Plated Steel -10AN A/C 90-Degree Female O-Ring Pilot with Service Port
Zirgo 10485 Direct Connect AC Bulkhead System with Jam Nut (-10 AN)
theBlueStone -4AN -6AN -8AN -10AN Braided Fuel Line Hose 10FT -10AN Nylon Braided for 5/8" Tube Size
EVIL ENERGY AN Hose Fitting Adjustable Wrench Spanner Lightweight Aluminum 3AN-16AN Black
5/8 Rubber Hose Connector with Pipe Clamps - 10an Hose Finisher with Screw Band Clamp for 5/8 Fuel Line Hose, 4Pcs/Pack Black Hose Clamps, Great for Fuel/Oil/Diesel/Gas/Air and Water Hose Pipe
Performance Tool W5201 270 Pc HNBR O-Ring Assortment
Aeroquip FCE1833 Nickel-Plated Steel -08AN A/C 90-Degree Female O-Ring Pilot with Service Port
Zirgo 10491 2 Port AC/Heater Bulkhead Kit (10AN/8AN)
Aeroquip FCE1014 Reusable Aluminum -10AN Swivel Straight Fitting
Black Aluminum 2 Port (1-L 1-L) Ac Air Conditioning Heater Hose Firewall Bulkhead
Earl's 1004ERL Vice Jaw
Kraken Automotive - 10AN Stainless Braided Hose for Fuel, Oil, Coolant and Air (10 Feet)
90 Degree -10AN Female to 10 AN Fuel Hose End One Piece Full Flow Swivel Seal Hose Fitting Adapter Black Aluminum Anodized
Zirgo 10488 Direct Connect AC Bulkhead System with Jam Nut -6 AN
Vintage Air 35813-VUG 10-Straight Beadlock O-Ring Fitting
2004 Neon SRT4 Seats Pair
BBK Performance Parts 1792 Power-Plus Series Performance Throttle Body
2 of Moog K7293 Leaf Spring Bumper
2 of Moog K704 Ball Joint
2 of Moog K3180 Control Arm Bumper
AMD 800-1370 Steel Trunk Floor Pan - Full 1967-76 Mopar A-Body
2 x Year One 17x9 wheels
Ididit Universal Tilt Floor Shift Steering Column Length: 32" 1120320010
EPAS Performance Electric Power Steering Conversion Kit Mopar A-Body 3002
Rechrome Both Front Vent Window Frames
Straighten and Rechrome F/R Bumpers
1.03" Torsion Bar Master Kit - Polygraphite - A Body (TOR4820P)
Bilstein High Performance Shock Set - Front & Rear (BIL7056063)
Greasable Control Arm Pivot Shafts
SPC 94460 Mopar RH Adjustable Upper Control Arm
SPC 94461 Mopar LH Adjustable Upper Control Arm
StopTech 928.63017 C-Tek Sport Brake Kit- Fronts Only
1967-1976 Dodge A Body Adjustable Strut Rods from Hotchkis Sport Suspension
1967-1972 Dodge A-Body Sport Sway Bar Set from Hotchkis Sport Suspension
Mopar Thrust Angle Shims for Hotchkis Sport Suspension Leaf Spring Kits
A-Body Offset Spring Hanger/Shackle Kit 1/2" hole
Leaf Spring Perches (Pair)
Custom length Axles and Brake adapters, lines, seals, gaskets
shipping
Rear End Narrowed, perches moved, drain plug added, welds smoothed
Built Torqueflite A-727 Full Manual Reverse Valve Body + Mopar 10-3/4" High Stall Torque Converter
1967-69 Plymouth Barracuda Carbon Fiber Dash Panel
Alternative Blasters
Goodmark RF fender patch rear
USCT1M1004 67-75 Dodge Plymouth A Body Level 2 Chassis Stiffening Pack
USCT1M1802 67 to 75 A-Body Transmission
USCT1M1305 67-75 A-Body Radiator Core Support Replacement with Adjustable Width
LED Tail Lights
1 x Leather Wrapped Tuff Wheel 1 x 306-TB Mopar 1969 Plymouth Barracuda Taillight Bezels 1 x 306-L Mopar 1969 Plymouth Barracuda Taillight Lenses 1 x 306-T Mopar 1969 Plymouth Barracuda Taillight Lens Trim 1 x 305-T Mopar 1969 Plymouth Barracuda Back-up Light Bezels 1 x 308-DL Mopar 1967-69 Plymouth Barracuda Dome Light Bezel 1 x 331A-6SET Mopar 1967-68 A-body Chrome Automatic Console Plate Kit
Hurst Shifters 69520001 Tunnel Patch W/ Template - Mopar A-Body W/ Tko
6.1 Hemi Biscuit Style Motor Mounts with biscuits
Billet Oil Catch Can fittings, hoses and mounting bracket used
Trunk Divider Hinge
U-Bolts [47] Axle Tube Diameter:: 3 inches
RF Fender, R&L Door, 68 Deck Lid
2 Year One Rallye Wheels 8x17
A-Body Hotchkis Leaf Springs
Rotisserie, Valance Brackets, Mopar Front Brackets (These I've sold already and subtracted the sale price I recouped)
Milodon 31000 Pan, 13331 Pickup
Remanufactured 6.1 Hemi Engine Complete (Some of the accessories not used will be sold)
Classic Auto Air - Air Condition Evap and inside vents controls
Tires Riken Raptor 275/40 17, 245/45 17 Tire Rack
340S Emblems Pair
VIN Tag Chrysler Dry Transfer
69 Barracuda Side Marker Set Front and Rear
American Auto Wire classic update wiring 510603
1/4 vertical seal
hood to cowl seal
door and trunk seal
roof rail seal
quarter glass hw 80084
side glass hardware 280102
side glass roller hw 280101
door end caps
door jamb u seals
TTI 61HC-C5, Polished Ceramic with Thermal Barrier,
BO125, Header Bolt M8-1.25 x 25mm
GA-HG61, Header Gaskets
GA-RG30, Collector Gasket
RED30x25x9, Header Reducer Adapters
G2 Axle and Gear Rear Disc Brake Conversion Kit 96-2049-DB
7" Round Semi-Sealed LED Clear Headlight Conversion
A-Body Automatic Center Console
Parking Brake Handle Lever Duster Dart Demon A-Body 68-74 (May try to incorporate a floor mounted hand E-Brake between the drivers seat and console)
1969 Plymouth Barracuda Cuda Floor Pan Exhaust Hanger Bracket NEW MoPar
Windshield Washer Nozzle Pair LH & RH Sides for 05-10 Jeep Grand Cherokee New (Filled and smoothed the Cowl Vent opening)
1966 67 68 69 70 Barracuda Cuda 2 Headlight Adjuster & Spring Kit New MoPar
1969 Plymouth Barracuda "A" body Body Bumper Kit New MoPar
Mopar 68 69 70 71 72 73 74 A-Body B-Body C-Body Window Handle Crank Spacer
Mopar 68 RoadRunner Satellite 69 Barracuda Finish Panel Trunk Hardware Fasteners
Mopar 68-74 Window Crank Handles Set Four Cuda Charger Challenger SuperBee NEW!
DMT MOPAR 67-69 Barracuda MEGA Splash Shield Set Kit Seals FOR AUTOMATIC TRANS
Data Plate Screws
Caliper Brackets Pin Type
Transmission Oil Pan Bolts
Shift Lever
Radiator to hood seal
Energy Suspension 9-9121G Black Polyurethane Bump Stops
1969 Dart Barracuda Vent Wing Window Tinted Glass
Noico Black 80 MIL 36 SqFt Car Sound Deadener
Mopar 66 67 68 69 Barracuda Dart Charger Road Runner GTX Trunk Lock + Key NEW
Passenger Manual Mirror
Drivers Remote Mirror
Door Handles
Flip Top Gas Cap
License Plate Lens
Mopar 67 68 69 Barracuda Cuda Fender Bolt Kit 1967 1968 1969 NEW
Front Bumper Bracket Frame Bolt Set 66-72 B-Body GTX Charger Road Runner
1967 1968 1969 1970 1971 Dart Duster Demon Barracuda Kick Panels
TPS Throttle Position Sensor For 98-07 Dodge Durango Dakota 3.9L 5.2 5017479AA
OEM Idle Air Control Valve IACV 4861552AC For Various Jeep Dodge Chrysler
MoPar 1960s-'70s TorqueFlite 727 Transmission ACCESS or INSPECTION PLATE ! O.E.
NEW STARTER MINI MOPAR DODGE PLYMOUTH 318 360 400 HIGHER TORQUE
MoPAR 67-70 STEERING BOX BOLTS CHARGER CHALLENGER PLYMOUTH ROADRUNNER GtX HEMI
68-74 Mopar A B E Body Cuda Leaf Spring Clamp Rubber Insulators
60-76 Dart Duster 64-69 Barracuda 1.5" Rear Leaf Spring Bushings Prothane 4-1017
Mopar 727 Auto Transmission Shift Lever
Mopar 67 68 69 Dart / 67 68 69 70 71 72 Valiant Hood to Radiator Seal NEW
1967 1968 1969 Dart Barracuda Vent Wing Window Tinted Glass
Mopar 64-74 Charger Roadrunner Cuda Challenger All Radiators Mounting Bolt Kit
Mopar 66 67 68 69 70 B-Body / 67 68 69 70 71 72 73 74 75 76 A-Body Mirror
Mopar 67 68 69 70 71 72 73 74 75 76 Dart A-Body 68 69 B-Body Manual Mirror NEW
Digital Guard Dawg i-key Push Button Start Passive Entry System
69 GTX, Road Runner, Charger, Barracuda Side Marker Set Front and Rear
1964-76 Mopar A, 62-72 B, 70-74 E Body Lower Control Arm Stiffening Plates 14 ga
Mopar A B E Body 11 inch Disc Brake Caliper Mount Brackets with Bolts and Parts
1968 69 70 71 72 Mopar A-Body Wiper Pivots Dodge Plymouth Barracuda Dart
Mopar Dodge Dart Anco 15A wiper arms Plymouth A body 66 67 68 69 70 71
USA RESTORATION*" SERVICE"* FOR MOPAR A-BODY DOOR HINGES DART DUSTER DEMON
A PAIR(2) RV gas strut shock spring lift Damper aftmkt rep SPD 2300-90
1968 1969 Barracuda Rear Valance Panel with Tips AMD
Mopar 727 Stainless Braided Flexible Firewall Mount Transmission Dipstick 25-3/4
12" Long 3/4" DD Stainless Steering Shaft 1" DD x 3/4" DD U-Joint Kit
2017 Dodge Challenger Scat Pack Center Console Automatic
NOS Glass Channel Weatherstrip 2932230
NOS VENT WINDOW HARDWARE! (LEFT & RIGHT!) - MOPAR DODGE CHARGER DART GTX TRUCK
RESTORED 3 SPEED WIPER LINKAGE 67/68/69/70/71 dart/demon 67/68/69 barracuda
SHI-195-40R RH FRONT FLOOR PAN
AMD-106-1267-S BUMPER BRACKETS
AMD-450-1370-R AMD Rocker Panel Right Plymouth Barracuda Coupe
Sherman Fender Patches 250-36L
POF-120-10003LWR CNRTL ARM PIVOT SHAFT KIT
AMD-A-270230HOOD HINGE RETAINER CLIP
QA1-52313K FRAME STOCK
AWW-500931 EXTERNAL BATTERY Terminal
Energy Suspension Torsion Bar Dust Boots 5-13101R
March Performance Serpentine Kit, MCH-40700-08, Chrome AC Manifold MCH-418-06
Auto Twirler Chassis, Car Body Dolly Cart
Sonnax T35-ALFY-07 - Flanged Yoke Tr6060, 8HP70, 8HP90
DA696BLK Dash pad for 1969-1976 A-body models. Color : Black
E43P Flat finish sill plates for 1967-1976 A-body models. Sold as a pair.
MY2 RH fender emblem, 1967-1972 A-body models, reproduction.
VC92 Reproduction "Formula S" fender emblem for 1965-1968
VC148 "Barracuda" fender emblem for 1969 Barracuda models.
P2785791 "Plymouth" hood nameplate
AH765100 Premier Perforated grain headliner for 1967-1969 Barracuda fastback models. Color : Black
RX42B Rear window reveal molding clip set for 1968-1969 Barracuda fastback models.
SKA68A 117-piece interior screw kit for 1968-1969 Barracuda fastback
WCRD690 Reproduction windshield gasket for 1968-1969 Barracuda fastback models
SM669 A/T shifter mechanism with woodgrain shift knob for 1969-1970 A- and B-body models.
DB3847 Rear window gasket for 1968-1969 Barracuda fastback models.
A975025 Reveal molding clip set, all models, reproduction.
MCK71 Dark argent center cap kit for use with YearOne cast Mopar Rallye wheels.
BH340B Trunk lid finish panel for 1969 Barracuda models. Black
FW974 Hood pop-up spring for 1967-1974 A-body models.
C316TK Technalon heavy duty car cover fits 1967-1969 Barracuda.
MP722BLK Rear lap belt in black with a black textured lift latch for 1968-70 Mopar A-body models.
MN722BLK 3-point conversion front seat belt set in black 1968-1970 Mopar A-body models with bucket seats
EP10B 2.5" i.d. Exhaust tips-pair, 1968-1969 Plymouth Barracuda models and 1970 Dodge Dart Swinger models. Polished stainless steel.
A0269P Exhasut tip hanger pair for 1968-1974 A-body models
Won't be using these M&H Wire Harnesses since we got the American Auto Wire classic update wiring 510603 that includes all these harnesses in their kit.
All from Year One
- RL41 Rear light harness for 1969 Barracuda fastback.
- L38445 Dash-side A/C and heater harness for 1968-1969 Barracuda and Dart models.
- L38569 Backup light harness for 1969 A-body models built up to November 15, 1968 with A/T.
Running Total $42,705.12
Each item's price is included in my excel workbook but doesn't copy paste well...
~200 separate line items!
Also a lot of items that were trial/test and then not used so removed... Some of the items listed above may also end up not being used because we found something we liked "Better" or just changed our minds... Like the Pat Blais Built, Zero Mile, RVB, Manual Shift 727 w/Chrysler Stall Converter $1859.97 + Core. Being replaced with a 2018 8HP70 8-Speed...
Ha! There's another $800 ($500 + $300 Shipping from Texas) to add to my list - 8HP70 Trans with Torque Converter.
Oh, and the US Car Tool Trans Tunnel $649 and the US Car Tool Trans Cross Member for 8HP $295.
Still need to add the Sound German Automotive PCS (Powertrain Control System) $1000 and PCS Paddle Shifter $550
Make that $45,499.12 and counting...
This is why you should never build one and never ever keep track of how much you spent...
Original Car Purchase Price, Bodywork, Paint and Labor not included...
There are more than a few items I didn't add to the list because sometimes I'm just too lazy...
Did I mention this will be my kid's car when finished? Call me crazy, I know.
He will be on the hook for 50% of the total cost. I think he's getting a pretty good deal.
He paid for the 6.1 and a few other items along the way but he is still in school and this past summer he was not able to work his summer job of the previous 3 years due to Covid-19
Snohomish County Public Works, Road Maintenance Division
cudaragtop
Also December 2020
Currently in the process of making mounting brackets for the AC Condenser.
They are the Aluminum pieces test fitted at the top and bottom.
After I have the condenser located I can route the AC plumbing.
Going to hide the lines as much as possible. Some will go between the inner and outer fender.
cudaragtop
January 1 2021
Happy New Year!
Got the AC Condenser where I want it and got a start on the plumbing.
First to make a hole for a 90* elbow to go through.
Test fitting with rubber lines that were included with the kit before making up the braided stainless lines that will be in the Engine Compartment.
Hard lines will run between the inner and outer fender.
Need to enlarge the hole a little bit more but need a new big step bit.
Will put a large rubber grommet in the hole after I enlarge it a little more.
O-Ring Female to O-Ring Male Elbow on the outside to a 90* down with service port inside.
Thought about a bulkhead in the core support but I'm liking how this is working out.
Next will be a flex line to a bulkhead through the inner fender.
Hydraulic Punch Driver Kit from HF.
First time using it. Got to admit, this thing works great.
1/8" thick core support, no problem. Nice clean hole. Forget the Step Bit.
Only $75 with the 25% off coupon 38183528
cudaragtop
January 3 2021
Made some more holes today. I'm really liking the Hydraulic Hole Punch Driver.
First for the Heater Lines. Drill Pilot holes first.
Then punch them out.
What it looks like from the inside.
A few pumps of the handle...
And presto... we have hole!
The back side of the heater lines Bulkhead.
Leaving the inside heater line plumbing for later, I moved on to Coolant Line Bulkhead install.
Same process but had to flatten the little channel for the bulkhead plate. I used the Hydraulic ram with 2 flat surfaces facing each other to flatten it out. I'm liking this tool more and more. Wonder what else I can think of using it for? I got some dimple dies to use with it but no dimple plans yet... Anyway, here are the coolant bulkhead fittings installed.
Next up... bend these to fit as needed.
Should be interesting. The -10 will not need much bending but the -6 line will be going all the way forward and around the corner in front of the core support to the Dryer.
Will start it at the dryer being sure to put enough bends to make a nice fit.
The -10 line will stop short of the core support and connect to a 90* bulkhead fitting.
The 90* fitting can go right where the -10 line ends...
cudaragtop
January 9 2021
Spent some more time on the heater and A/C lines on the inside.
Just test fitting so far.
I'll make a little "L" bracket to mouth the Heater Hose Valve to the bottom of the cowl.
Just sitting there loose right now.
cudaragtop
January 9 2021
Made my first ever A/C Hardline. Well I should say I bent my first Hardline.
Working from the From Dryer to the bulkhead on the firewall in the inner fender.
Got to say that it really turned out nice if I do say myself...
Had to creatively bend it to keep it from being too long. I used a length of leftover copper tubing to do a mockup first then the real thing. A little nerve racking but made it through.
Only bought the one 60" -6AN Female to Female line so I only had one chance to make it right or screw it up...
The 90* down and then 180* up was to take about 3" of length out or it would have been too long.
It was the best way I could think of to consume some of the excess length...
I thought about putting a couple 90* bends in this long straight side instead of the 90* down + 180* in the front to take up some of the extra length but I'm happy I did it the way I did.
Here is a shot that shows the whole line from end to end.
Have a couple ideas of how I will shield the lines from damage from road debris inside the wheel well.
Maybe slide a conduit over then fill with expanding foam insulation...
A chunk of heavy duty hose right there on the 90* bend and a few mounting clamps strategically placed along the length.
One Hardline down and one to go.
The -10AN hardline will be much easier. Going to be pretty much just a shorter straight shot to a 90* fitting to a bulkhead fitting through the side of the inner fender.
They won't follow exactly the same path but I'm going for functionality over looks and no one will see them once the fender is on.
I did consider making a long -10AN hardline following the -6 but the -10 is a lot harder to bend small tight bends.
I should be able to get the -10 line done tomorrow.
Once I have the Hardline done the Bulkhead will be located and I'll make up a rubber -10 line from the compressor to the Bulkhead.
Rubber lines for test fitting but the finished A/C soft lines will be Stainless Steel Braided lines.
Soft lines in the passenger compartment will be rubber though.
Pure joy that I was able to bend this to fit in one try!!!  :banana:
I do have a plan to protect the lines in the inner fender from road debris...
You will just have to trust me on that.
cudaragtop
#116
January 10 2021
Installed the Bulkhead fitting through the inner fender, made up a temp -10 rubber line to go from the compressor to the bulkhead.
Both will be braided stainless but I'm using the rubber lines for mockup first.
I used my router to make a single bulkhead plate out of aluminum and just rattle canned it black for now.
Backed it up on the other side with a large galvanized washer.
Adapters for Male -10AN O-Ring to -10AN Male 37*
These will convert the Bulkhead and Hard Line Male -10AN O-Ring fittings to 37* fittings to mate up with the black 90* elbow that is -10AN 37*
I couldn't find a 90* elbow fitting that is Female -10AN O-Ring to Female -10AN O-Ring... If I could have found one I would have used it.
These should work fine though.
cudaragtop
#117
Sunday January 17 2021
Decided to do something about the valve cover bolts on our 6.1
I will clean the originals up and will end up using 4 of them for the Ball/Socket mating for the 6.1 half covers. Going to hang on to the rest since they are really expensive to replace.
Tried a couple different solutions but think I like this one best.
M6 Stainless Steel Allen Hex - 6 x 35mm together with
M6 Black Anodized Aluminum Conical Countersunk Washers
The Washers are 5mm tall and 25mm diameter with a 6mm hole
Still using the thick rubber washer/spacers off of the original hardware.
The Aluminum washer is just a bit larger diameter than the rubber and are a cone shape on top.
If you have done a G3 Hemi in an A-Body, you know how tight it is to the passenger side inner fender.
These give a little more clearance to the inner fender at the shock tower on the passenger side.
I tried it with Black Oxide instead of Stainless Steel too but I like the contrast of the stainless steel against the black better.
Looks like this.
Clearance to the passenger inner fender.
Here is a tip.
Remove the long factory hardware before installing or removing your G3 in your A-Body Mopar
The paint on your passenger inner fender will thank you.
Long 4mm Hex Key Allen Wrench here.
Everywhere else I could use a 4mm Allen socket on a 3/8 drive ratchet and extension...
Better angle. Not quite as close as it looks in the picture above.
But it is close...
Yup, I definitely like this better.
These don't look bad when they are new and these definitely need to be freshened up.
I'll freshen them all up and use 4 for the half covers and the rest will get squirreled away.
Won't see these with the half covers on but they definitely look better now.
2 for each side next to the intake for the ball sockets that the half covers mate to.
The little things need to get done too.
Small steps in the right direction also get you closer to where you are going...
For comparison of factory to my replacement
cudaragtop
#118
01/18/21
Using Corbeau Seat Bases with Neon SRT4 seats.
Cut the SRT4 mounting brackets off with an angle grinder, drilled and bolted the seats to the brackets. Bolted them to the floor with the US Car tool perimeter tunnel just sitting in there and the Challenger Console.
Tried a pair of Planted Technology seat bases for E-Body, thinking I could make them work but decided to try Corbeau A-Body bases instead.
The Corbeau mounting holes lined up with the Barracuda mounting holes perfectly.
Will be selling the Planted Technology E-Body seat bases.
These are the ones I used. Ordered through Summit.
Corbeau D344 Driver side
Corbeau D345 Passenger side
Link to my full thread on FABO
https://www.forabodiesonly.com/mopar/threads/g3-hemi-69-barracuda-fastback-father-son-project.364889/
Link to way too many pictures in my Google Photos Project Photo Album "Project 69 Fastback"
2016 - Today
cudaragtop
Noticed some of the pictures were not showing in a few of my earlier posts and fixed some of those links.
Also added several updates to the project to bring this thread up to date from 2018 to today.
:wrenching:
2016 - Today
