avatar_shawge
Colored wiring diagrams - 70 Cuda/Challenger
Started by shawge, April 04, 2017, 08:02:35 PM
shawge
Did some wiring om my 70 Challenger over the winter holidays. I grabbed the scanned manuals from mymopar and added some color to the wiring diagrams using GiMP. Below are the results after a few hours.  Hope they are useful to others as they were to me.  Let me know if you see any errors.  Also let me know If other years are needed as it would be easy to add.
Cheers!
Edit: 70 Challenger standard dash wiring diagram
Wheel spreadsheet
JRMac73
Very nice
Sent from my SM-G930V using Tapatalk
This is the coolest!!!!  MAN, nice work!   :clapping:
This is front light harness with relays is from @chal340    :bravo:   Here's what he said about the diagram he made:
"I put one relay for low beam and one double relay for the high beam. (you can put 2, 1 for outside high beam and 1 for inside ) You can see schematic of the harness and of the relay."
chal340
Wow, very nice. I'm going to print them and put them in my garage.
70 Dodge Challenger 340 A66.
HUSTLESTUFF
What program can you use to open these file?  Can't seem to find one
Aar1064
Impressive. Thanks for doing the work and posting.
fc7cuda
Nicely done.  :twothumbsup:
Looks like it was pain-staking work and should have been done originally this way by the factory.  :alan2cents:
ec_co
Quote from: HUSTLESTUFF on April 05, 2017, 03:32:38 AM
looks like they are standard .jpg files which should open in any picture viewer/tool.
shawge
#12
Colorized wiring diagrams from the 1972 Plymouth chassis service manual.
Edit: let me know if you see any errors, thanks!
Wheel spreadsheet
CudaMoparRay
Quote from: shawge on April 28, 2017, 11:53:46 AM
From the 1972 Plymouth chassis service manual. I will attach more as I finish them.
This is brilliant work thanks again
shawge
Added more 72 Barracuda diagrams. Finishing up on the rallye and engine diagrams.
Wheel spreadsheet
